Question about Kitchen Ranges
Burner ignitors wont stop clicking - Kitchen Ranges
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Does this happen on all burners?
    President:
  • 744 Answers
Hello, your problem is going to be 1 of 2 problems, 1st did you spill liquid on the switch? if so the switch has shorted out, unplug the appliance for 24 hours to dry the switch out then plug it back in...if after 24 hours it is still clicking you have a bad switch (these are the burner knobs) check each one with a ohms meter, the one that is bad will read infinate on your ohms meter when it is switched off. If you have any other questions please feel free to comment. Good Luck!! Mike
Posted on Oct 06, 2009
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Wolf 4 burner stove developed a non stop ignitor clicking
If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Non stop ignitor clicking
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
48" dual fuel burners clicking wont stop after lit.
just remove it from the board .
and please be carefull
.FRANKIE.
May 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Ignitors won't stop sparking
If your ignitors on the burners continue to click after cleaning it is because they are wet. The spark module is not sensing the flame is on therefore still telling it to click. Just leave all burners on high for 20 minutes until they dry out and stop clicking. The clicking is not dangerous. Just annoying. If they continue to click you may have some grease residue or cleaning residue on the ignitors. Take a piece of sandpaper, nail filer and file the tips of the ignitors where it has metal above the porcelain white part. Good luck.
Sep 20, 2008 | Kitchen Ranges
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Kitchen Ranges Logo
192 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
