Question about Epson Stylus 2200 InkJet Photo Printer
2200 locked up
Red light is flashing rapidly on paper feed. Printer will not respond to any commands.
  • butlerad Feb 15, 2008
    Upon powering up my Epson 2200, a few of the ink level lights and the paper feed light come on. The ink is not really out.
    I turn off the printer and the power buttons doesn't respond until I press it several times. Then the ink lights come on gain. This time on but on different colors than before. There are no obstructions.
    What to do?
What to do?
Posted on Feb 15, 2008
  • Epson Master
  • 1,879 Answers
Disconnect the printer from the computer - power off printer - check for obstructions / torn papers - power on
if paper light is still on/flashing and pressing it does not do anything - you got a hardware issue - call manufacturer for reccomendation
this might help also - http://www.epson.com/loyalty
Posted on Jan 03, 2008
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
Epson Stylus Photo 2200
Hi there. I managed to find an excellent resource that should help you solve your problem. Try the suggestions given here http://www.fixyourownprinter.com/forums/inkjet/24337 i would start with "holding both paper and ink buttons then powering on untill the paper light flashes and then holding the ink button for 10 secs" Let me know if this helped. D.
Aug 02, 2007 | Epson Stylus 2200 InkJet Photo Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
All ink cartridges flashing - changed all inks to see if that was the problem...still flashing. Also the paper light is flashing. I checked for obstructions and nothing is there. Is there a lock on the...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts.
Sep 25, 2010 | Epson Stylus 2200 InkJet Photo Printer
Paper won't feed. starts then red light comes on paper button.
Is your paper pushed in far enough, or is it jamed. eather pul lpaper out, or push paper in. don,t worry about it
Jul 03, 2010 | Epson Stylus 2200 InkJet Photo Printer
THERE IS A HIGH PITCHED NOISE AND BOTH THE PAGE AND PRINTER LIGHTS ARE FLASHING RED. THE PRINTER IS NOT RESPONDING TO ANY COMMANDS, EVEN NOZZLE CHECK AND HEAD CLEANING.
Check for a paper jam as this is the #1 cause of high pitched noises in this model. If there is no paper jam then replace the ink cartridges with new ones as it will not respond if ink is empty. If none of this fixes the problem then you will need an epson repair center as the internal parts are not user serviceable. Hope this helps.
Aug 19, 2009 | Epson Stylus C84 InkJet Printer
Suddenly won't print
found paper fanfolded in back, over the drum. Removed paper, still not consistently feeding through but at least I know where the hang up is.
May 12, 2008 | Brother HL-2040 Laser Printer
HP Photosmart 7450 stuck cartridge
not a solution, my paper feeds past the point where printer5.gif would normally begin. Then flashing light changes from green to red and print operation stops. Printer cartridge1.gif appears to be stuck in far right area of cartridge track.
Replaced drivers as above and still have the same problem.
Mine started after I had replaced the color cartridge. Mailed the old one to HP already so can't put in old cartridge.
If I unplug printer from computer, I get same results. Does the driver software install in the printer?
Geo
Mar 28, 2008 | HP Photosmart 7450 InkJet Printer
EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
See your printer documentation.
Nov 08, 2007 | Epson Stylus Photo R320 InkJet Printer
There is a red light flashing
From the OKI site, I found this information. My problem is a Flash 2 Blink, which is a problem with the cover or minor error, whatever that means. I can't figure out how to fix it. Any suggestions greatly appreciated!
Flash type Ready LED (Green) Manual feed LED (Amber) Error LED (Amber) Meaning Flash 1 -- slow blink X ecblank.gif ecblank.gif The printer is processing data when printing has been suspended. ecblank.gif ecblank.gif ecblank.gif X The image drum required changing or toner is low. Flash 2 -- blink X ecblank.gif ecblank.gif The printer is receiving and processing data during printing or the printer is resetting itself. ecblank.gif ecblank.gif X ecblank.gif The printer is requesting manual paper feed. ecblank.gif ecblank.gif ecblank.gif X There is a printing error, problem with paper or a cover open. ecblank.gif X X X There is a minor error with the printer. Flash 3 -- rapid blink X X X There is a major error with the printer.
Oct 27, 2007 | OKI B4250 Led Printer
Epson Stylus 2200 InkJet Photo Printer Logo
228 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
