Question about HP Deskjet 5940 Photo InkJet Printer
Prompt says there is a problem with right ink cartridge. It is 3/4 full. It was printing fine, then it just stopped with the prompt I have described. It is an HP 96 cartridge.
I bought a new cartridge.
Posted on Oct 07, 2009
My printer stopped printing? Canon Pixma 210 New
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32\ and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Apr 20, 2011 | Canon PIXMA MP210 InkJet Printer
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
No cartridge prompt
try to clean contacts on cartridge and print head with alcohol, if it doesn't help, try to put back your old empty cartridge, if it will prompt only for that new cartridg, you bought, than the new cartridge is probably broken, replace it
Jul 10, 2009 | Brother Multi-Function Center MFC-240C...
Ink cartridge assembly not going to correct posy to replace black
Remove the cartridge and put it back in. If still it doesn't work, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the black pattern or no black appears at all, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Epson RX580 can't change ink cartridge
well..sounds like your new print cartridges are not too compatible..I recommend you get the right ones
Aug 19, 2008 | Epson Stylus RX580 InkJet Photo Printer
HP Deskjet 5940 Photo InkJet Printer Logo
175 people viewed this question
Seeker5211
Seeker5211
