Question about DeLonghi Coffee Makers & Espresso Machines
The coffee comes out very slow and it seems like there is some sort of clog.
    Sergeant:
  • 186 Answers
This may be caused by hard water mineral deposits.Run a cup of regular vinegar through a normal brew cycle followed by a full pot of water to rinse the vinegar from the machine. This will remove most mineral deposits.
Posted on Oct 07, 2009
Saeco talea giro plus
Yes it sounds like the pump is clogged with scale.
Oct 26, 2016 | Saeco Coffee Makers & Espresso Machines
Keurig machine is clogged
try using a paper clip or long pin to clean the 2 tiny holes in the upper prong that pokes thro the top of the coffee cartage. I had the same problem and that fixed mine
Sep 05, 2014 | Keurig B30 Mini Coffee Maker
Coffee brewing to slow
Have you taken the sprayhead off (remove basket and look up)? This copper tube gets clogged with lime/calcium and needs to be cleaned. They have a delimer that usually comes with a new bunn, (12 inch coily spring) that needs to be ran up the tube that the sprayhead is connected to. If it is still slow after that, the the tank itself has a buildup inside.
Feb 28, 2014 | Bunn NHB Coffee Maker
Keurig
Check the needle that pierces the bottom K-Cup, those can clog which can cause it to run slow.
You might also try de-scaling it: http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
If this doesn't help, it could be an issue with the B60 itself. If it's under warranty still, call Keurig, they'll likely send you a new one. The B60's seem to have control board issues. Every once in a while mine acts up, and I have to pull the plug, reset it, and fiddle with it til it starts working correctly.
Jul 10, 2012 | Keurig Special Edition B60 Coffee Maker
The coffee is very slow coming out.we have decalcified the machine many many times,taken the grindchute assembly out and cleaned it,and now we are running out of options Please help
Coffee coming out too slow could be a number of problems.
I'd start with the grinder and make sure it is set to the right settings. If the coffee's too fine it will cause the coffee to come out slowly.
Next it could be a dirty brew group. The internal part of the brew group has a glass ball inside of it which is used to during the infusion process. Take the ball out and make sure that area is all clean.
Restrictions in that area can cause the coffee to come out slower.
Your next possible scenario is the pump. Vibratory pumps do go bad from time to time, and a bad pump would cause the coffee to come out slow.
If its a newer saeco machine with the J style boiler, it could be clogged due to lack of descaling.
Slow coffee can be caused by any one of these issues. Usually it is the first one.... the grinder settings.
A tip is to never go under the 3 setting under any saeco machine as the machines for some reason cannot handle anything lower all that well.
Also remember these machines are ment to produce an "espresso like" coffee, and not traditional espresso. They are not capable of producing espresso that you would otherwise be able to make in a traditional handle machine.
Hope this helps.
Mar 29, 2011 | Saeco Vienna SuperAutomatica Coffee...
Ho do i clean the taming filter n my ura F9
you can not, not with out taking machine apart my mom put coffee in the top powder fill and forgot to push the powder button grinder then put more coffee in and when the piston tried to tamp the coffee in was completely clogged up error code came up , $ 250 to service I completely took unit apart I would not req. in less you are a very tech minded person nightmare of parts all working together but anyway the tamping screen is screwed to the piston and is in middle of the machine water is push from the bottom, thur coffee , thur screen , thru piston, up thur a small hose and falls down into the service head and out the two ports to cup I was able to complete remove coffee and remove screen and clean got machine back online ran cleanning program all ok if machine completely clogs and error code comes up it can not be fixed any other way if coffee comes out slow or you get a short cup of coffee you can run a cleaning program to remove the coffee stuck in the piston area the problem is caused by old coffee grounds sticking to the dosing part this part both puts coffee into the piston and take it out make a cup of coffee and look down the door on top of the machine with a flash light when the dosing door opens up and the used coffee puck is drop into the used bin , if you see used grounds on top of the dosing part then next time you make coffee it will end up mixing with new coffee after a while this can cause clogging . try to use diff. coffees some are ground to fine and most of the problems come from the powder dosing door. by the way I and my mom both have a F9 unit I have had the slow and short problems with my machine but it only happens when I use the powder dosing door good luck to all steve
Dec 31, 2010 | Jura Capresso Impressa F9 Espresso Machine
Hot water comes to slow
It sounds like your water line may be clogged. Buy some descaler powder and follow the instructions on the package to clean away calcium deposits from inside your coffee maker's water lines.
Oct 22, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
From slow to no drip brewing....no descale issues....clogged?
clean the needles and if that dont work call keurig and get a replacement
Sep 20, 2009 | Keurig B60 Coffee Maker
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Coffee drip seems to be clogged?
changer de sorte de café le noir semble colmater les ouverture
Nov 21, 2008 | Saeco Odea Go
Open Questions:
Coffee Makers & Espresso Machines Logo
242 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
