Question about Health & Beauty
My andis model Ls is not cutting anymore, and the two cutting pieces aren't together. How can I fix this?
Well, my guess would be it needs to have the cut hair cleaned out via> pressured air like kind to blow out your computer etc. then, you must lubricate blades or they get dull faster, like a chain saw going thru dirt. turn on the clippers, rest the cutting blades only (in shallow bowl) put blade cleaner in and run clipper about 2 min. turn of allow to drip off and wipe. In a pince you can you kerosene to clean blades. good luck
Posted on Oct 10, 2009
Can I swap sharp cutting blade from one size blade to another?
Well you can either buy a new one from a local shop
http://www.angliaclipperservices.com/dog
Or wait a while and send them off for sharpening
http://www.angliaclipperservices.com/Clipper_Sharpening
May 26, 2016 | Andis Dog Clippers - AGP Super 2-Speed...
My toutliner cutting too sharp
Adjust your blade. Remove it from the clipper, and then loosen (don't remove) the two screws that hold the blade and cutting edge together. Use a FLAT surface, like a ceramic sink top or flat piece of tile, and push the cutting edge down and angle the blade with the cutting edge facing the flat surface down to about a 30 to 35 degree angle. Use your thumb to hold in place until you can retighten the screws. Under a light, inspect to see if it is level (it will be noticeable if it isn't) or oil the blade and touch it to a clean dry piece of paper. If it is level, replace the blade on the trimmer, and edge your beard. It should be better than brand new. This also works when it doesnt seem like the blade is cutting sharp anymore. ALWAYS make sure the cutting edge is lower than the blade or you WILL CUT YOURSELF or YOUR CLIENT!
Mar 29, 2014 | Andis T-Outliner Hair Trimmer
My juki ddl 555-5 with old model auto cutter does not cut thread anymore. how to fix it?
Recording how it fits together before starting is a good idea. Drawing a picture is another method including plenty of detail such as colours. It once made all the difference when reconnecting the hydraulics on a truck. If you feel confident, you could re-try different combinations or have an electrician check it
Feb 28, 2014 | Sewing Machines
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
Sep 23, 2012 | Andis Improved Master Clipper/Trimmer...
Why is my lexus ls 400 trunk leaking
ls 400 - trunk leaks water. Fix -- Under the trunk seal at the bottom/rear you'll see that two pieces of metal come together. The adhesive / sealant that is used at the factory seems to leak with age. pull off the seal and use a good adhesive sealer to prevent water from leaking down between the two pieces of metal. Reinstall the trunk seal after it has dried and set properly.
Sep 06, 2010 | 1998 Lexus LS 400
Not Trimming Properly
For the replacement of blades please visit the Andis website at www.andis.com. Choose USA, then service, then use and care. Once you are at the use and care section find your model and click on it to bring up the instruction manual.
If you are still have problems there are two service stations in Maryland as listed below. If neither of these are close to you you can send the unit into Andis for repair.
Water's Appliance Service
216 E Diamond Ave
Gaithersburg MD 20877
301-258-7500
800-225-5009
Hemps
13407 Graceham Rd.
Thurmont MD 21788
301-898-9916
Fax 301-271-3610
If you should have any further questions please do not hesitate to contact the Andis customer service department at 1-800-558-9441.
Thank you for choosing Andis.
Aug 28, 2008 | Andis Edjer 15515 Beard Trimmer
Bobbin
have good eye hand cordination and lick the end of a perfectly cut thread up to the bob make sure not too have any loose thread on the end or will not go threw
my mother when i was little taught me to sow on and old 32 singer up her new 65 singer when she bought it used i never could use the stick to sow
or you can cut a piece of fishing line little fast acting glue to the ends together or grease thick sowing grease this will keep fish line and thread together as your putting in bobbin
fishing line about 1/2 foot piece
May 16, 2008 | Brother LS-2125 Mechanical Sewing Machine
Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Apr 23, 2008 | Andis 04603 Hair Trimmer
My hose cracked on my ep238
I've had the hose brake on this vac at both top and bottom several times. You can pinch the ears that hold the hose assembly to the wand and vac connection and get at the piece that the hose screws into. Remove the old piece, cut the hose cleanly and screw back in, then snap back together. They don't seem to have this hose anymore and since the vac also has problems with its cord assembly I'd say your best bet is a new vac once the hose can't be fixed anymore.
Apr 13, 2008 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Andis Outiliner II Trimmers
Please return your unit to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177 for repairs. If the unit is less than one year old please also return a copy of your receipt with the unit and all repairs will be done at no charge. If the unit is older than one year there is a $6.50 service fee and $5.00 shipping. There may be additional charges for parts depending on what needs to be done. If you would like to speak to an Andis customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 21, 2007 | Andis Outliner II Hair Trimmer
Health & Beauty Logo
342 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
