Have a 87' Ruud furnace, was working last night & now nothing works. I replaced the thermostat & the pilot is on, however the fan with not run & the main burner will not start. (the breaker on the house is not tripped) Can you help with any suggestions?
  • Danny Clark
    Danny Clark May 11, 2010
    Take the front panel off the furnace and look for the controln board and a small blade type fuse. Do you see one?
  • 80 Answers
I believe these furnaces still used a fan/limit control. The fan will not come on until the heat exchanger is hot enough. Your problem most likely lies with the burner not lighting. Make sure the fan/limit control dial has turned back all the way to the correct temp, if not, replace it. The fan/limit control is inside the aluminum cover in the middle of the burner section. Also, the gas valve may be bad. See if you have 24vac at the gas valve during a call for heat. If you do and it's not opening.......bad gas valve.
Posted on Oct 07, 2009
How do I get my AC running again? Ruud UBHC AC unit isn't running. Started yesterday or today.
Sounds like there is no control voltage. Either the transformer to reduce the voltage from 110 volts to 24 volts is not producing the 24 volts needed for control voltage, or most furnaces have a small 3 or 5 amp fuse mounted on the main control circuit board that may be blown. Other "outside circumstances" may involve a break in the thermostat wire...more than likely the red wire if you are getting nothing to work. I have seen evidence of "critters" that have chewed through the low voltage thermostat wiring that would keep the thermostat from controlling anything. To check this, go to the furnace and jumper the red & green wire to get the fan running just to isolate if it is a thermostat wiring severred. Good Luck.
Dec 11, 2014 | Ruud UBHC Air Conditioner
Furnace does not start
Furnaces usually have a high temp limit switch that turn off the gas if the plenum gets too hot, as it may if the fan fails (or air flow is restricted) and the furnace is running. These are in series with the gas valve so if they fail open will prevent the furnace from ever turning on.
Trace the circuit from the transformer through each component (including the thermostat) and check for an open circuit at each location. Replace the one that has an open circuit.
Also check the fan to be sure it is working properly when you directly connect power to it.
Mar 10, 2017 | Heating & Cooling
My Duo Therm furnace was working last night and not this morning
I would make sure there is power to the unit before I attempted any repairs. Gas being available will not allow the thermostat or gas valve to operate if there's no power to them
Dec 04, 2013 | Heating & Cooling
My Ruud Silhouette gas furnace ugdg 07 model blower stays on. The heat and air both work but it is pricing my energy bill higher. Whats the cause and can I just turn off the power to the unit (what about...
Problem could be the thermostat setting in "fan on" mode. Thermostat could be shorted between Y,R and G. Fan relay points soldered together or main board shorted.
Nov 03, 2013 | Ruud Gas Furnace - Excellent Condition -...
Ruud gas furnace burners won't ignite
Remove the stat cover and jump out the red and white wires. If the furnace still doesn't come on, it is your t-stat. Replace it.
Mar 12, 2017 | Heating & Cooling
Ruud 90 plus will not blow hot air
My Ruud is a different model, so this may not work. Remove the cover to the burners. Look on the left side for a small rubber hose going to a metal cylinder. Remove the hose and blow through it to remove any moisture. Replace the hose and see if the burners start up.
Feb 23, 2013 | Ruud Rheem Rgfe09ezcms Gas Furnace
I have a a Ruud furnance, model UGAC 095c. The problem is the pilot light goes out once or twice a day or late night. The thermacouple was replaced, new filter also. I also observed the pilot light and lit...
check the thermocouple is tight in to the valve , condtion of thermocouple could need changing , is pilot stong blue flame could need cleaning .
Feb 06, 2011 | Heating & Cooling
My ruud deluxe 89 furnace is not working. The fan will work but does not blow hot air. When I move swith to Auto I hear the click, but nothing happens after that. I have changed the filters which were very...
the directions on mines says to turn the pilot off for 5 min to clear gas out the pipeline. then turn it to the PILOT position and push down while lighting it, then once its lit turn it to ON. ive tried that but its not working. i dont know if im not doing it long enough. did anyone help you yet? FW
Nov 30, 2010 | Ruud Heating & Cooling
Power outage last night now my RUUD High Achiever AC Unit model# UPNE-048JAZ will not work
Power surge may have taken out your control board (in the furnace, does the fan work?), possibly the transformer (in the furnace) or possibly the capacitor (in the A/C). Call a professional.
Aug 22, 2009 | Heating & Cooling
Fan on unit will not turn on in cooling mode
Check to see if the green thermostat wire is conneceted to the "G" terminals on the thermostat and on the furnace.
Apr 20, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
