Question about Nikon Speedlight SB-800 TTL Flash
SU-4 on sb800
Please can you explain further what the su-4 is used for.
i am also unable to get the flash repeat working even though it is set right
Unlock The Superslave in Your Nikon SB-800 http://strobist.blogspot.com/2007/08/unlock-superslave-in-your-nikon-sb-800.html
Posted on Dec 31, 2007
  • Strobist Dec 31, 2007
    Can't edit? From the above site...
    SU-4 mode, a legacy, wireless, quasi-TTL mode for which
    the SB-800 is backward compatible.
How will i Root my FIREFLY S80 Super SU is not Working onto it.. Thanks!!
What you'll need to do is load TWRP recovery up first, then flash Super Su from recovery,that is the issue your having as to why Super Su won't install binary. There is not much to explain with this one, Android Jelly bean is hard to crack.
Jan 13, 2015 | Android Cell Phones
When I access the menu by holding select to change to remote or SU-4 mode the flash crashes/freezes and I have to take the batteries out. Also when you go into SU-4 mode it lets out a beep sound and it...
Did you try to reset all settings as told in the manual on page 12?
Press the (mode) and (on/off) buttons simultaneously for
approx. 2 sec. to reset all settings, including the custom
settings (except the distance unit selected in m/ft) to
their default values.
If the problem stays, please check you finnished your repais correct. (nothing lose in the unit and no cables switched, no false connections)
Oct 30, 2013 | Nikon Speedlight SB-800 TTL Flash
Hotshoe and sync cable will not fire strobs. However, if I connect the sync cord via my SB800 the strobe will fire.... Help :D
What strobe are you using besides the SB800? Probably the best solution is to use a hotshoe extender for the mystery strobe (like an SC-15), and then set the SB800 in SU-4 mode (i.e. fire when any other strobe around it fires).
Sounds like the mystery strobe isn't triggering correctly with the sync signal that the body is giving through your adapter.
Mar 09, 2011 | Cameras
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
Synchronizing two sb-800s with a nikon d300
You knoq the SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
To access the SU-4 remote mode hold the "SEL" button in for a few seconds until the menu appears. Scroll down to the SU-4 setting and turn it on.
When using this method set the flash to manual and set the power as needed.
Regards.
Apr 13, 2010 | Nikon Speedlight SB-800 TTL Flash
How do I use two sb800 one on the camera and one behind a groups of people to eliminate the shadows on the wall
The SB-800 has a slave mode called SU-4 in the menu. It activates remote flash. When your on camera flash fires so will the slave flash. The slave flash will need to be able to "see" the light from the on-camrea flash to work.
Mar 08, 2010 | Nikon Speedlight SB-800 TTL Flash
SU-800 and SB-600 line of sight
Remember that the SU-800 works by sending out an infra red beam as the trigger pulse, when out doors available light can swamp the sensor on the side of the flash with too much light, therefore the flash cannot "see" the pulse from the SU-800.
Also if you refer to the manual, you will find nikon recommends working within approx 30 / 60  degree angle of the sensor, so if you were working behind the camera with the flash it would have had even more trouble.
As you found when you used your hand you strengthened the output beam for the flash to be able to pick up the pulsed output beam. You may need to create some kind of hood, to place in front of the SU-800 to direct the beam in the direction you need it to work.
Hope this helps  Ian
Aug 07, 2009 | Nikon Speedlight SB-600 TTL Flash
LCD moniter locking up on SB800
I would pack it back in to the box with a detailed description and send the flash back!
Jerry G.
Mar 30, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 firing but not syncing??
I had that same problem with the SB600 and the SB 800. Solutions; get a new one. After about a year of usage the sb600 started giving me that problem. It flashes but it does not sync. It still works as a remote unit, but not mounted on the camera. The SB800 just went to a coma last weekend. No sync at all, not even as remote unit, no strobe function, just a bright flash, when triggering the test button with new fresh batteries, it flashes at max power once and takes around 7 seconds to recycle. No multiple flashes at all. I had to buy a new one.
Jan 09, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-800 TTL Flash Logo
337 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
