Question about Microsoft Computers & Internet
Windows 98 I have no usb support,I reformatted hard drive a while back on old toshiba sattalite laptop it went back to windows 95 then I istalled( upgrade to 98)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
You are having a driver issue. Whenever you reinstall an OS or upgrade this is a recurring problem.
1.
open system properties / hardware / Device manager
2.
scan over your list and notice any highlighted entries
3.
Right click on a highlighted entry and select update driver, if it ask "can windows connect to the internet " select yes.
4.
after all updates are completed reboot your system.
5.
Enjoy
Please rate very helpful if this helps your problem. ^_^
feedback is appreciated.
Posted on Oct 07, 2009
Testimonial: "driver issue was a given(commonknowledge problem)I can't access internet with this laptopIneed the usb hub to do that I dontuse adialup or ethernetcar"
Max hard drive size for Toshiba Satellite 2430-S255
Unless you are running Windows 3.1, Windows 95, Windows 98 and your drive format is FAT16/32 and not NTFS, there should not be any problem with a high capacity drive. Don't make the HDD size too big: it may be costly. If you have money to burn get two drives, one internal system disk, and the other an external storage/ backup drive.
Dec 14, 2013 | Toshiba Satellite 2430-S255 PC Notebook
I recently bought a Toshiba Satalite laptop to replace the one I dropped which was also a Toshiba Satalite. I had taken out the old hard drive and installed it in the new one but now it wont do anything...
Yes it does matter. XP was configured for the old Toshiba and this will only work if both Toshiba laptops are exactly the same model.
To get your new Toshiba operating, put the new hard drive with the Vista operating system back in the Toshiba laptop.
To transfer your data from the old hard drive, purchase a USB adapter hard drive case and place the old hard drive inside this case. This will then be an external USB hard drive.
Plug this USB hard drive into the new Toshiba's USB port and it will detect it as an external storage/hard drive. You can then open the various folders and files and copy the data files to your new Toshiba.
To free up disk space on this USB hard drive, delete the Windows folder, Program Files folder and other folders that are no longer needed.
Use this hard drive as a backup hard drive etc.
Sep 11, 2010 | Toshiba Computers & Internet
I cannot plug any divice.
The laptop is too old for Windows 7 to be installed onto it. Windows 98 will need the USB 2 drivers installed before you can plug a USB 2 drive in and have it recognized.
My advice to you would be to upgrade Windows 98 to Windows XP, then you will have an up to date computer.
Regards.
Feb 19, 2010 | Toshiba Portege 320CT Notebook
How to reformat a notebook laptop with no CD-driver?
Remove the hard-disk - it will usually connect via an IDE or SATA-compatible interface. You can then connect it to a computer (internally, or via eSata / USB / 1394 enclosure). You can then format it from that computer.
When you say no CD-driver, do you mean Driver or Drive?
if there's no CD drive, it should either have a floppy drive (in which case, any system book disk can re-format the HDD), or USB-booting capabilities.
If there's no driver, than a Windows 2000 / XP CD should be able reformat the disk - when you boot from it, it will load drivers off the CD. You don't need to install Windows normally, the recovery console can format disks.
A Windows 95/98/ME boot disk/CD will allow formatting, but only in FAT/FAT32 file systems (you will probably want NTFS, which 2000 and XP can create)
Sep 05, 2009 | Computers & Internet
Fairly old toshiba laptop with hal.dll error wont even boot now..
Well it must be an error when you install the windows XP...If you choose just to upgrade the your system then it might have an error on dll. Please reprogram your system i mean reformat your system. And not just upgrading well if ever you have an important data in the system then you must have a externat storage device then take it on your laptop.
Mar 08, 2009 | Toshiba Computers & Internet
Toshiba P30 notebook
You may need to take the hard drive out and find a portable USB hard drive case to put it in ...if it is 3 years old it is probably an IDE drive ...newer ones are SATA drives....then hook it to another computer and and check it ...you can also reformat it in the portable case on another computer then put it back in the laptop and then reinstall windows......if it isn't recognized by the other computer then it probly wrecked the hard drive somehow..
Hope this helps
Jan 12, 2009 | Toshiba Satellite P30 Notebook
Re-installing Windows '95
Check your bios settings for the usb ports they may be disabled in the bios. Enable them.
Your CD Drive should have been enabled if it allowed you to run windows 95.
Check your make and model numbers for the hard ware that you need to run and post back a comment and I will see what drivers I can find for you.
Nov 08, 2008 | Dell Inspiron 2200 Notebook
Want to get music files off old toshiba laptop windows 98 no burner
hi evin
you could use a usb stick to transfer the music from laptop to other pc ?
riz.
Jun 23, 2008 | Toshiba Computers & Internet
HARD DISC PROBLEM
Better you can go for new laptop
Feb 26, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
