Question about Dell Latitude D520 Battery PC Notebook
Drive not showing in windows - Dell Latitude D520 Battery PC Notebook
  • Nathan Ramojal May 11, 2010
    What OS you are using? Is it Windows XP Pro/Home or Windows Vista Ultimate/Home/Business? Thanks.
  • 3,940 Answers
Run the fixit utility here
http://support.microsoft.com/kb/314060
Posted on Oct 07, 2009
After install window not show may hard drive
Right-Click "Computer", Manage, Storage/Disk Management. What you see here is what you have, or at least what Windows thinks is connected. If you have a missing hard drive, check your hard drive connections.
Jun 26, 2014 | Computers & Internet
Tip
Using Windows Disk Management Utility to Manage Internal and External Disks
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
The Disk Management utility can be accessed in two different ways.
#1- You can open the Control Panel,
Click on Administrative Tools,
Click on Computer Management and the Computer Management window will open.
#2- Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a “Drive” and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”)
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter “C”.) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters “F” or “G”. In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
on Jan 29, 2010 | Computers & Internet
My computer will not pick up my drive when i put it in
The windows disk management utility will help solve this issue most of the time. Use the directions below:
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 20, 2011 | Computers & Internet
Hi, I've just bought a Sumvision Cyclone Primus 2TB and after connecting it to my laptop it installs the drivers. Once this is complete a Microsoft Windows pop-up comes up saying "you need to format...
Try putting the unit back on your laptop and using the windows disk management utility. The directions are below. Windows Vista is a bit differenct than either windows 7 or XP.
Right click on you "Computer" Icon in your start menu
A menu will open
Chose "Manage"
See if this helps you manage the external disk and get it formatted so you can use it on your laptop.
Thank You,
Brian
Mar 02, 2011 | Office Equipment & Supplies
Sir my pen drive is not showing in windows xp .\r\...
Try this,
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. On the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right
click on your portable drive and click change drive letter and paths.
4. Then a assign a new drive letter which is not being used by any of your drives in My Computer.
5. Finish assigning the new drive letter your portable drive will show up in my computer with
other drives
Hope it works for you
May 20, 2010 | Microsoft Windows XP Professional With...
I put the flashdrive into the port but I do not understand how to get the work onto the drive? It said that I connected it right but it did not show me how to copy or download work onto the flashdrive.
A flashdrive shows up in Windows as a new drive letter un Windows Explorer.
If you right click on My Computer (XP), Computer (Windows 7) you can select explore or open.
The dialog box that opens is split in half. the left side shows the "drives" and corresponding letters. Typically, you will have a Local C:\ for your Primary hard drive, CD Drive D:\ for a CD/DVD and the flash drive will show as Removable Drive E:.
To copy work to the new flash drive, you can select save as from your program and select the drive letter that you saw the removable drive named in Windows explorer.
You can also, from the folder named My Documents, copy the file by right clicking on it, then selecting the flash drive letter and pasting into the empty window associated with it on the right side of the divided Windows Explorer screen.
Apr 16, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
CANT FIND IT ON MY COMPUTER
have u insert it? check it at first in device manager then inform is it showing or nt?
Mar 24, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My hitachi hard drive dosent show up in my computer
The reason it's not showing up in XP is because microsoft made updates to drive handling in Windows 7.
The disk is in essence too "advanced for XP"
Your best solution is to copy the data off the drive onto the windows 7 machine, then format the drive using windows XP. Once formatted, copy your files back onto the drive from the windows 7 computer and both will be able to share the drive.
Hope this helps FixYa,
Crankstart
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif
Feb 22, 2010 | Computers & Internet
My san disk 2gb pen is canot open but light is blinking &showing remuvabal disk on my computer
USB Pen or stick drives usually use the letters "F" or "G" drives on your computer. If these drive letters are being used, the USB drive will not be available. Also, if this is the first time you are using the USB drive, it is possible the drive is not formatted. Although this is unlikely.
I will outline instructions below to use the Disk Management tool in windows to see if the drive shows all the drives connected to your computer. If your computer is recognizing the drive as you describe. I am confident USB Pen drive will show up in disk management. You may be able to assign a drive letter and make the drive visible in you my computer window.
The directions for using disk management are listed below. A note of caution, do not make any changes on you Disk 0. or "C" drive, as this is you main hard drive that starts your computer.
A menu will open
Chose “Manage”
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu. The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have no disk will not show as active drives on the top section, but can be seen in the lower section.
The lower shows each drive, their drive letter and status. The left section will have small boxes showing drive numbers. Drive 0 is usually your main hard drive. To the right of the smaller section is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”) This is the area you can right click and get a menu that will allow you to: open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition.
In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows. A drive this is having a problem may show that it needs to be formatted. This can be done from this window as described above.
Please follow these directions and see if you can make your drive visible. If you have any questions about the instructions or need further assistance, feel free to reply to this message and I will assist you further.
Brian
Jan 29, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
C drive showing 0bytes and won't format but D drive shows 33GBs??
Do you want to format your C:?
if you want to format just insert a bootable windows service pack 2. It has a format option installing a new windows.
Or if you don't want to format because there is an important file..
insert windows service pack 2. then there is an option before the format if you want to repair or configure your old Operating System. You can access there. its default location is C:\WIndows\...
May 17, 2009 | Cavalry Storage CAUE37400 400 GB IDE Hard...
Dell Latitude D520 Battery PC Notebook Logo
16 people viewed this question
Alun Cox
