Question about Hunter (25417) Ceiling Fan
How do you change the light bulbs in the top light unit..It is completely encased & I'm not sure what screws to loosen.
  • 8,404 Answers
Generic response
Start by getting a ladder to see what is on top. In my experience, these fans are made in a way as to be easy to maintain ... not hard.
It may be that you just lift the glass ...
Please let me know what you find
thanks
a
Posted on Oct 06, 2009
How do i gain access to the bulb to replace it?
I assume you're talking about the light that is inside the microwave & not the cook top light. Unplug unit. Normally your microwave will have a plastic or metal panel on the top front or back of the unit. (The bulb is not always changed from the inside of the unit.) Simply remove the few screws that hold the panel on & remove it. This should give you simple access to the bad bulb. Replace bulb then reassemble. Some free standing units require the entire outside enclosure be removed.
Mar 01, 2016 | Microwave Ovens
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
How to fix mitsubishi eclipse tail lights
open the trunk. locate the plastic screws that hold the carpeting in place at the top of the trunk. remove one or two of the screws nearest to the tail light by simply pulling them straight out so you can pull back the carpeting in the trunk. now you will be able to see the screws holding the tail lights in place. remove them using a wrench to loosen the bolts, making sure you remove all of them, there should be four or so. use a flathead screwdriver end to gently remove the tail lights. now you are free to change the bulbs by twisting the plastic caps for removal from casing to expose the bulbs or you can unplug the tail light and install a new one making sure to add the bulbs to the new unit. thread wiring through loops and you're done. would be helpful to ensure all are working before reassembling. repeat process on other tail light if necessary.
Feb 04, 2012 | 2001 Mitsubishi Eclipse
Bulb has gone in the Tachometer dial..can you tell me how to change bulb & how difficult it is..do i have to remove all the nose panels. thank you
Undo the screws around your dashboard and control dials and lift out the plastic dash. this should leave your dials in place. You now have easy access to your light bulbs. If like most bikes the wire with the bulb going into your tachometer should be encased in a rubber plug. pull this out and change bulb. Should take about 20 minutes to complete job.Good luck
Aug 06, 2011 | 2007 Hyosung GT125R Supersport
How to change the globe to the headlight of my Kia Pregio GS 2005 van
To replace headlight bulb of kia pregio van: You only need Phillips screw driver and 10mm socket or open wrench. Open the hood, remove front grill with 4 phillips screw. This will give you room for your hand to pull out the headlight housing later on. Next is remove the signal light housing by unscrewing the phillips screw on top of the headlight housing then pull out the signal light housing and remove the bulb. You will see 2 pcs 10mm bolts on the side which hold the headlight. Loosened and remove the bolts on headlight holder then pull the headlight sideward. Remove power supply socket before removing it completely from the van. Remove bulb socket, spring clip, and busted bulb and replace with new one. Reassemble the disassembled parts in reverse order. That's it, will take you only 10 minutes.
May 27, 2011 | Kia Rio Cars & Trucks
How do I change a headlight unit in a ford focus as I cannot find the bolts
Open your hood and look at the headlight assembly from inside the hood. You will see screws that you can loosen to get the headlight covers off, and the bulbs should just be "screwed" in the headlight units. There shouldn't be any bolts and screws on the outside. Also, to adjust your lights, you should have an adjustment "screw" on top of the headlight unit when you open the hood.
Dec 30, 2010 | 2000 Ford Focus
The small green LED light on garage door motor head out
That little green bulb just flickers when the logic board is receiving a radio signal and is also used to send a code to assist with diagnosis. It does not keep the opener from working. You say the door is 'stuck'. If it is stuck in the open position the trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain to relieve the pressure and the opener should run. When the door is closed locate the 'up limit' on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Then tighten the chain.
Mar 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Fog/driving light bulb replace
There is a panel under the corners of the bumper that is held by two screws. You can access the Light bulb by removing the panel, careful that when installing the new bulb's. Try to keep from touching the glass and it's a go thing to change both side. Good luck
Mar 14, 2009 | 2003 Pontiac Montana
How do you change the low-beam light bulb on Subaru Tribeca? Cant get the headlight assembly out. Have taken the two screws out, but something else holding lower corner.
I just had to do this and learned the hard way.
First take the battery out.
Second remove the plastic cap covering the low beam bulb
Thirdly there are 2 screws holding a wire tension spring against the bulb. Losen the screw towards the outside of the car (Don't touch the screw closest to the engin).
Once you do this, the bulb will come out and you can replace it.
Jan 14, 2009 | Subaru Tribeca Cars & Trucks
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Hunter (25417) Ceiling Fan Logo
56 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
