Question about AT&T 8925 Tilt Smartphone
No service in known good area - AT&T 8925 Tilt Smartphone
    Problem Solver:
  • 17 Answers
Check your sim card. If you have an old cingular card. You need to update your sim. Or your phone will need service.
Posted on Oct 07, 2009
B14 code
The B postcode area, also known as the Birmingham postcode area,[2] provides postcodes for the boroughs of Birmingham, Solihull, Sandwell and Walsall and parts of Warwickshire, Worcestershire and Staffordshire in England.
Jul 02, 2014 | 2007 Acura MDX
Names
Personal Area Network
Local Area Network
Metropolitan Area Network
Wide Area Network
Don't forget about SAN, CAN, DAN, and WLAN.
Storage Area Network. Also known as Server Area Network, Storage Area Network, and Small Area Network.
Campus Area Network. Also known as Controller Area Network, or Cluster Area Network.
Desk Area Network
Wireless Area Network
http://en.wikipedia.org/wiki/Computer_network#Scale
http://en.wikipedia.org/wiki/Local_area_network
Regards,
joecoolvette
May 11, 2013 | Computers & Internet
Power outlets on console and in lighter area don't work,fuses under dash are OK>
You need a 12 volt test light,connect gator clip to known good ground,probe center bottom stud in lighter,if light is on you have power to system and the most common cause is a bad ground to the system,to check for a good ground ,reverse gator clip to known battery voltage and touch Sharp lead to lighter housing if lights up you have a good ground.
Aug 26, 2011 | Honda Accord Cars & Trucks
I have jag 2000 s type im getting enigne fail safe mode sign i went jag dealer they gave bill of $1093.89but problem is still there i have 129000 miles on it ,when sign comes i feel little bit of power...
First try to find a Good Independent Jaguar specialist, as these tend to give much better service on difficult problems than the main dealers who always seem to just want to put new parts on your car and give you a massive Bill ! Fail safe mode can be caused by many things. faulty temp sensor - throttle position sensor - air flow sensors- faulty coils - the list is endless ! Get the codes read on your car by a specialist - this history will show areas where the fault lies. If the codes are not too clear a running monitor test on your car when in use can help to identify the problem area. But make sure you take it to a GOOD garage ! Don't panic as the fact that the car is still drivable and the fault resets when restarted shows that the problem is in one of the electronic sensors - components or could even be a corroded wire in a cable loom. There is a list of known problem areas and reoccurring faults that will be known or accessible to a Jag specialist or Good Garage. Hope this helps - good luck.
May 28, 2011 | 2000 Jaguar S-Type
My computer does not have sound unless it's plugged in
First check if the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed in the Computer:
Click on Start, type WINVER in the Search area and then press the Enter key.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option and enter 'WINVER' and check whether Windows Vista SP1 or 2 is installed in the Computer.
To check the version of the BIOS installed in the Computer:
Click on Start, type MSINFO32 in the Search area and then press the Enter key.
In the System Information window check the BIOS version.
If the installed BIOS version is not R0231Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR190E&upd_id=3745&os_id=28
This is a known issue with a VGN-CR series Computer when Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
Installing the BIOS update should resolve the issue.
If the issue still persists after installing the BIOS update then you may try installing the Audio Driver from this Link.
NOTE: Please first go for the BIOS update as it is a well known issue with a VGN-CR series Computers.
If the issue still persists, follow the steps as mentioned on this Link to resolve the issue.
Good Luck!!!!!!!!!!!!!
Nov 14, 2009 | Sony VAIO VGN-CR190E/L Laptop PC Notebook
No sound coming on my laptop VGN-CR220E
Please first check whether the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed:
Or
If the installed BIOS version is not R1121Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3618&os_id=28
Oct 26, 2009 | Sony VAIO PCG-K23 Notebook
My Kodak DX4900 lense will not retract when I turn the camera off. If I hit it, then it retracts. It has no problem coming out when I turn it on, but won't retract when I turn it off unless I hit it....
This is a list of the error codes, obviously some aren't of much help but ...
E1 The memory card is not compatible with the DC50 Zoom Camera. Use a compatible card. E10 Take the camera to your dealer for service. E11 Take the camera to your dealer for service. E12 Take the camera to your dealer for service. E13 Take the camera to your dealer for service. E14 Take the camera to your dealer for service. E15 Take the camera to your dealer for service. E16 Take the camera to your dealer for service. E17 Take the camera to your dealer for service. E20 Reseat the memory card.
or
Replace the memory card with a known good card.
or
Take the camera to your dealer for service. E21 Confirm that the memory card is compatible with the camera.
or
or
or
Take the camera to your dealer for service. E22 Reseat the memory card.
or
or
Take the camera to your dealer for service. E23 Confirm that the memory card is compatible with the camera.
or
Take the camera to your dealer for service. E24 Confirm that the memory card is compatible with the camera.
or
or
Take the camera to your dealer for service. E25 Confirm that the memory card is compatible with the camera.
or
or
Oct 05, 2009 | Kodak EasyShare DX4900 Zoom Digital Camera
Noisy startup when cold, sounds like valve
Hello onarock844...The Hyundai 2.4 litre and the 3.3 litre are known to have valve train noise. Some sooner than others.
The timing chain tensioners on the 06 and 07 Sonata 3.3 engines built before August 4, 2006 are well known for developing wear that allows them to make a tapping or rattling noise for a short time after a cold start. This noise can be mistaken for a lifter noise, although the actual source is in the front cover area of the engine. Hyundai has released a technical service bulletin on this problem, which describes installation of an updated design timing chain tensioner (part #24410-3C300) to correct this noise issue.
Ask your dealer to refer to Hyundai service bulletin #06-20-002 for information...If this has already been corrected,,,and the noise is coming from the upper engine area and not from the timing chain area, then the valve clearance will need to be adjusted. This is done by disassembling the valve train and installing slightly different size tappets to change clearance.
This is a fairly labor intensive process, so if you are still under factory warranty then you will want to go over the dealer's head and get the Hyundai zone rep involved to get it covered before your warranty coverage expires...
I recommend useing a full synthetic engine oil, i know in a few cases where the noise has stopped when the oil was changed over to synthenic, also a high quality filter is important, such as a purolator.
Good luck...i hope this helps...please rate me a fixya.
Jul 29, 2009 | 2006 Hyundai Sonata
T.V DOES NOT WANT TO POWER ON CHECK ALL CABLES THERE PLUGED IN BUT STILL NO RESPOND FROM THE T.V (Samsung LN32B360 32" LCD HDTV (Black)
The power supply is known to go bad. I would see if it is working. A servicer in your area should be able to check this out. These are known for bad caps.
Jul 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
Open Questions:
AT&T 8925 Tilt Smartphone Logo
61 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
