Question about Whirlpool MH1150XMQ Microwave Oven
EVERY THING SEEMS TO BE WORKING LIGHTS FAN TURN TABLE, BUT THE HOT DOG IS COLD
  • Whirlpool Master
  • 8,404 Answers
Check the door safety interlock switch.
if you need more help, let me know
a
Posted on Oct 06, 2009
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Frigidaire microwave doesn't work
Don't have a fix for your problem, but my Frigidaire microhood just did the exact same thing--about the same age, started cooking some food and it worked for a few minutes and then just stopped--time kept going, light stayed on, but turn table stopped and fan noise cut out. I tried it a few more times and it seemed to fade in and out and then stopped trying.
Nov 30, 2009 | Microwave Ovens
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
My emerson mw8117w just stopped working
hi! first thing first check all the fuses for busted.
Sep 15, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Microwave runs but nothing is hot.
Sounds like the magnatron (the bit that makes the radio waves) has failed.
not economical torepair it,just replaice the whole microwave
Apr 05, 2009 | GE JVM1870 Microwave Oven
Microwave not heating
If the fan is running and the light is on, indicating that there is power to the unit, then there are only 2 likely reasons for this. Either the controller that decides what power to put through has failed, or the magnatron (the thing that creates microwave energy) has failed. SOMETIMES, there is an internal fuse that will blow, but still allow the light to come on and the table to turn etc, My current microwave came from my local dump and when I examined it, there was a spade connector loose on one of the components, I put it back in place and it still works 7 years later. You could take the back off and take a look, but frankly, I would think it unlikely you are going to sort this out. If you do decide to try, the usual rules apply, be sure you can see how it comes apart, work on it UNPLUGGED from the power and make sure that if you put it back together and test it you are happy that you have reassembled it correctly. You really don't want it microwaving YOU instead of your food
Mar 01, 2009 | GE JVM1653 Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
