The fan is going on but it is not increasing the heat of the house.
    President:
  • 3,433 Answers
Fan is on, but are the burners? aShould check.
Posted on Oct 07, 2009
Will a house fan running in front if fridge make it work harder or make fridge quit all together
That should be a help not a hinderance. The fridge tries to expel heat from the condenser, normally at the back, any additional air flow past the condenser must be helpful for getting rid of the heat. Any fan close to the fridge must be creating some sort of increased air flow.
Jul 02, 2015 | Refrigerators
Air/heat not blowing from vents, can feel the heat but it's not blowing, I turn the knobs to high blow and it won't do anything, its cold outside,
if the fan does not increase speed as turned up replace resistor assembly usually in heater housing under dash.if doesn,t nave separate resistor assy.it is the fan switch
Feb 11, 2011 | 2002 Buick Century
We have bought a house with on old air conditioner and no handbook. What are the symbols on the remote for heat and cool please? ie. How can I tell which is which?
Fan mode- 3 leaves of fan.
* synbol for cool
Symbol of sun refers Heat
< or > temp increase or decrease
on/off button refers for switch on or off.
Hope it's helpful msg?
Dec 21, 2010 | LG Heat cool Window Air Conditioner
I have a GrandAire and the aircon works fine; when I turned the heat on, it seems to work fine (warms the house), but the fan in the outside unit is not spinning when the heat is on...is this a problem?...
I think your unit is working in good condition. If you keep in cool mode the out door fan runs to condensate the heat in condenser by taking fresh air from the ambient. And when you keep heat mode, definitely the ambient temp will be too less.I fit takes from their then compressor will get frozting and it couldn't work properly. Depending on pressure increase, the fan will automatically run and stop. Don't worry. Thanks.
Dec 16, 2010 | Heating & Cooling
Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
Jan 11, 2010 | Heating & Cooling
When we are not at our cabin the temp is set to 57. Every time we go there and set it to 70 degrees the furnace will heat for 40-60 minutes and get to low 60's, then I notice hot air is not coming out of...
It sounds more likely that your fan is not pushing enough air across the heat exchanger. If you have a multi-speed fan, I would suggest increasing the blower speed. Otherwise you will continue to cycle on and off on the high limit. Also make sure that you do not have any return or supply vents blocked off, as this often times will cause the same problem. Hope this helps.
Nov 20, 2009 | Heating & Cooling
Dell Demension runs great but loud fan noise that takes a long time to shut down. What going wrong?
I had a similar problem with excessive fan noise on my Dell Dimension 5150. The solution was to replace the worn heat sync compound that was between the cpu and the heat sync itself. (£0.99 ebay)
Jul 10, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
CPU Fan Doesn't Spin
First time that I had heard of a Sony Vaio VGC-LS1, so I had to go take a look. Pretty Cool!
I can only tell what I think from a tech standpoint of view on it's processor fan.
1.This computer is housed in a housing that incorporates the LCD screen also. It's set up just like a laptop, except the LCD screen is in the body. (Housing)
This means you not only have the heat of the processor when it's running, you also have the heat of the LCD screen.
Plus it's all packed into one tight 'box'.
Processors give off a lot of heat by themselves. If they aren't kept to a certain thermal limit, they will burn up. Literally! Like ON FIRE!
When a processor goes beyond that thermal limit, there is a built-in Fail Safe feature that turns the processor off.
In ANY computer I've seen, or worked on, the processor fan is constantly spinning. As the load for the processor increases, so does the heat given out by the processor, and the fan spins faster.
It is my contention that you have a bad processor fan. I would at least ask a tech in your area, and see if this is so.
If your computer is turning off on you while you are using it,
Apr 13, 2009 | Computers & Internet
No increase in humidity after installing whole house humidifier
have you checked the damper ? is the motor running the right direction ? have you increased the water supply to it ? you need to be sure that it is coming on only when you have a call for heat, normally your humidistat should be installed near the return, or on the return duct, for proper sensing, you could try holding a pan of steaming water, placing the stat above it, not to close, to see if the stat shuts off the hum, a little trick, that way you will know if the stat works ok, hope these helped, thanks for the question, mr.grzz
Jan 22, 2009 | Honeywell HE220A1019 Whole House...
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
