Question about Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW
I have a mini freezer and needs to build a lock for it, where can i get the accessories
    President:
  • 1,304 Answers
You can install a regular hasp self tapping screws
Posted on Oct 07, 2009
Why haier freezer is beeping
Either way if you had the doors opened a lot, it should like you probably have frost build up preventing proper air flow. You'd need to pull everything out of the freezer and remove the lower back panel inside the freezer. If there is frost build up, you'll need to use a hair dryer to thaw all the frost out. The unit will continue to beep until the set temperature (0 and 38) are reached so that could take a while even after thawing out all the frost build up.
If removing panels sounds like more than you can handle, you can always unplug the unit for 24 hours and leave the doors open to allow the unit to defrost on it's own.
Oct 16, 2016 | Haier Freezers
The freezer does not freeze anymore
Hello Rina;
My name is Peter. I am a retired field service technician.
You need to provide more information.
Upright freezers are very simple.
There is a label on the side wall witch has your model number on it.
1.) Locked in the defrost mode - If nothing is running except for the light being on then you are locked into defrost. Your defrost timer is in the back behind a metal plate. With a large flat head screw driver slowly turn the shaft clockwise one click at a time to turn the freezer on. If it turns on this component will have to be replaced.
25676024-2tl4mzw4ix4qkonroxm2e5ag-2-0.jpg Cost: $20.00
2.) Is your freezer cool? You may have a frozen drain and cooling coil. Un plug your freezer and leave the door open for 24 hours. After several hours check to see if you have water build up in the bottom of the freezer. If so, you are going to need to keep soaking up water unit there is no more.
3.) Can you hear the cooling fan running? These fans are $35-65.00.
4.) You may have a bad thermostat, bad defrost heater, or a refrigerant obstruction.
I need more information from you to determine the problem and the model number.
May 02, 2015 | Freezers
ICE BUILDS UP IN LIEBHERR FREEZER
Needs a new defrost timer. If ice builds up then you are not defrosting. If you are not defrosting then the t-stat will read the ice and think it is down to temp and shut off.
Mar 23, 2014 | Freezers
My new frigidaire freezer is moistening around the door's lock
If mold builds up there you can get really sick!!! it is not supposed to do that. maybe the door lock wasnt put in right and the freezer is making it moist. well you should use your warranty. ... complain like hell too and refuse to pay any service charge if they demand
hope this was helpful
Mar 29, 2010 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
How do i make a freezer? I am want to make a glass box with a freezer inside. should i reuse parts of a mini freezer? if so, how?
If you are attempting to make a freezer that will actually function with all glass panels, then you are going to be sadly disappointed. Not only will the freezer not make nor hold temp due to lack of insulation and heat gain, but the glass panels will most likely crack under the extreme temperature differences.
I am going to assume you are building a freezer as a training aid or something along these lines. If so, I would recommend using Plexiglas vs. real glass.
I would also look to a local restaurant that is getting rid of an old small reach-in cooler or freezer. I would then take the components out of the donor and install them into the new project.
Hope this gets you going. Good luck with it.
Dec 26, 2009 | Freezers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have a freezer in our Lab building , it stays
You need to have a vapor barrier installed between the freezer
Jul 16, 2009 | Freezers
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Magic Chef 7 cu. ft. / 198 liter Chest Freezer CFC0735GRW Logo
73 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
AJMAL KHAN
Tom Chichester
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
