Hoover Floormate H3000 Upright Wet/Dry Vacuum
Problem for Hoover Floormate H3000 Upright Wet/Dry Vacuum
The bottom tank is not filling up with water and
By elway414 on Oct 06, 2009
The bottom tank is not filling up with water and it seems like less liquid is being released out of the top tank
Best Solution
posted on Oct 11, 2009
Helpful)
elextek
Rank: Guru  Vacuums  Expert
Rating: 87%, 123 votes
Your diffuser may be clogged above the brushes. check the front squeegee to make sure that it is in tact. Remove the lower tank and look at the intake hose, these often tear over time due to plastic getting stiff.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" I found out it was the bearings going bad and ended up replacing it with a newer model " - elway414
Popular Solutions for Hoover Floormate H3000 Upright
Questions and Unsolved Problems for Hoover Floormate H3000 Upright
Do you recommend Hoover Floormate H3000 Upright Wet/Dry Vacuum?
Answer
Answer
Hoover floormate Gets little to no suction when set to both Dry and Wet Pick up.
Answer
When you push the solution button nothing comes out, only puts out water just a little if you pump... (More)
Answer
hoover floormate h3000 not dispensing cleaning solution after sitting for extended time
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repairmen
in , AR
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
