Question about Texas Instruments TI-30XA Calculator
Display reads DEG on top with L under when I turn on. will not clear
  • Texas Instru... Master
  • 8,064 Answers
When you turrn calculator ON the angle unit is reset to Degree and the DEG indicator is displayed. I do not know what the L is for, but you can get rid of the DEG indicator during calculator operation only if you change angle unit to RADians or GRAdes. However it will be replaced by the indicator for the new angle unit. After the power down, the unit will be back to the default DEG. What can you do about that?
Hope it helps.
Posted on Oct 30, 2009
E00002 canon ir2525
Code E002-0000 Description Fixing unit temperature insufficient rise
1.The reading of the main thermistor is less than 115 deg C continuously for 400 msec 1.3 sec after it has indicated 100 deg C. 2.The reading of the main thermistor is less than 150 deg C continuously for 400 msec 1.3 sec after it has indicated 140 deg C. Remedy 1.Go through the following to clear the error: CLEAR > ENGIN > ERRCLR; and then turn OFF and then ON the power. 2.Check connection of the Connectors (Thermistor Connector and AC Connector). 3.Replace the Fixing Main Thermistor (Film Unit). 4.Replace the Fixing Assembly. 5.Replace the DC Controller PCB (PCB4).
Aug 05, 2015 | Canon Office Equipment & Supplies
Tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
Reset the condition in service mode:
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
main or sub thermistor for 200 msec.
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
on Aug 03, 2010 | Office Equipment & Supplies
How to clear error code e000002-0000
Hi
I have found a list of error codes for your machine here:
Error Codes Canon iR2270 Code E002 0000
and it looks as if your error is described as follows: Description The rise in temperature of the fixing assembly is faulty
While startup control is under way, the reading of the main thermistor is less than 115 deg C continuously for 400 msec 1.3 sec after it has indicated 100 deg C. While startup control is under way, the reading of the main thermistor is less than 150 deg C continuously for 400 msec 1.3 sec after it has indicated 140 deg C. Remedy Reset the condition in service mode: COPIER>FUNCTION>CLEAR> ERR. Replace the main thermistor. Replace the DC controller PCB. You can check all error codes on this page by choosing the relevant code from the drop down menu at the top right of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Canon IR 2270 Digital Copier RECONDITIONED
How do I clear "DEG" from display?
You can switch between Rads/Deg/Grads. Deg is the one you want to use. So, to answer your question, the "DEG" is suppose to be there so that you know what mode you are using. If you don't have the manual, here it is:
http://support.casio.com/pdf/004/fx82SOLAR_E.pdf
Nov 11, 2014 | Casio FX-260 Solar Scientific Calculator,...
How do you change it to degree mode
Press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Gradappear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press 1.
Let me know if this helps!
May 02, 2011 | Casio FX-300MS Calculator
Ok so my math hw only gave me the degree, minute, sec format of the angle. How do i input it in the fx 155 es to work out and find the rest of the angles, sides, etc?
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
This showed you how to enter angles in DMS or DD. For the rest 'find the angles, etc.' you should refer to your trigonometry manual: You have the definitions of the trigonometric ratios, the sine law, the cosine law to resolve triangles.
Feb 24, 2011 | Casio FX-115ES Scientific Calculator
Machine show an error E000002 Model iR2530 Canon Imagerunner
these means the reading of the main thermistor is less than 115 deg C
deg C.
deg C.
power.
TO ENTER SERVICE MODE:
press *
press 2
press 8
press *
If you cant clear the error code these means that you need to replace fixing heater.
Hope that helps!
Aug 19, 2010 | Canon Office Equipment & Supplies
I have fix and deg on my fx 992s and I am only getting results and can only enter numbers to 1 dp. How do I remove this?
Ok. Press [MODE] key three times until you see a screen that shows Fix SCI and NORM. Under FIX you have 1, under SCI you have 2 and under NORM you have 3.
You cannot remove FIX, unless you replace it with another display MODE (SCI or NORM or ENGineering).
You cannot remove DEG unless you change angle unit to RADians or GRAds.
To set angle Unit You start by pressing MODE twice to get a screen that displays DEG, RAD and GRA and below them 1, 2 , qnd 3. If you press 2 the angle unit will be set to Radians. DEG will disappear, but RAD will be shown.
Whatever the display format for numbers (FIX, SCI, NORM, ENG) you can always enter numbers of any length. It is their displaying that is affected by the FIX,SCI, etc. mode.
If you want more than 1 decimal digit, press [MODE] three times, then select 1: FIX. You will be asked to select the number of decimal digits (from 0 to 9). You could take 2, 3 or 4, or anything you want.
  1. To summarize: Indicators on screen reflect the configuration or mode you are in.
  2. They can be replaced by others but you cannot clear the screen of the indicators.
  3. You can select the number of decimal digits in your results,
  4. but there is no restriction on the numbers you enter.
Mar 03, 2010 | Casio Office Equipment & Supplies
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-30XA Calculator Logo
261 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
