These burners are not supposed to be operated uncovered. If indeed the burner is covered and it is still causing the controls to burn than the resistance for that burner is failing and the burner should be replaced. Thank you, Dana
Water over flowed on unit. There was a crackle and pop. Light on control knob stays on for left rear...
(More)
Water over flowed on unit. There was a crackle and pop. Light on control knob stays on for left rear and left front and rear burners will not heat. Cathie
I am trying to re-connect the wiring on a Model JED 8400 Downdraft Cooktop. Wiring scheme is as...
(More)
I am trying to re-connect the wiring on a Model JED 8400 Downdraft Cooktop. Wiring scheme is as follows From Power Source: White Black Unshielded Coppper Wiring harness in appliance White Red Green Black Please supply proper hookup
My Jenn-Air JED8430 cooktop has a an edge that was cracked by a heavy pot lid. It's right on the...
(More)
My Jenn-Air JED8430 cooktop has a an edge that was cracked by a heavy pot lid. It's right on the edge about 1/4" by 1/12". How can I repair it? Possible install an outer border for protection?
The exhaust fan on my 6 year old model will not turn on, though the burners heat fine. I suspect...
(More)
The exhaust fan on my 6 year old model will not turn on, though the burners heat fine. I suspect the switch, but cannot find an easy way to remove it without taking the unit out of the counter. Help!
