The back of my 22'' flat screen LCD TV cable connection step broke off. Can I use a TV Tuner Box to get TV and change the channels?
  • 80 Answers
Yes you can. If you have RCA jacks ( the red, white and yellow ones )
Posted on Oct 06, 2009
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Feb 18, 2015 | Samsung LN32A330 32 in. LCD TV
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
How do I find the right channel to set my tv on so it will receive cable tv
If it is a cable box and you are connecting via coaxial cable using the rf converter in the box it is usually channel 3-4 but it can often be switched. If it is a satellite box it may use a high channel number like 73. Keep in mind that there is a traditional tuner and a digital tuner in your tv set so you made need to connect the cable and then do a channel setup for it to sense the active channel.
The image quality is best when the cable box is connected in this order from poorest to best; coaxial cable, rca cables (red,white,yellow), s-video (on older televisions), component video and optical audio using the three yellow, blue, green cables for video and a white or red for audio or optical input, DVI, or the best, HDMI with support for 1080p and audio. On your TV you should use an HDMI cable and simply change the Input or source button to that. The HDMI cable integrates video and sound and it will transmit a dolby surround signal to your TV just as a separate optical connection will.
Nov 27, 2013 | Insignia 42" LCD Flat-Panel HDTV
Screen says no signal . How do I connect cable?
Connect an antenna, cable box or satellite receiver to the RF Input on the rear. Set the input to Air, or Cable, and run a channel scan for Digital Channels if using an Antenna.
Sep 27, 2013 | AOC L22W898 22 in. LCD TV
Can't get channels 4 and 5
If you direct enter them with the remote (04 enter) and get a blue screen either the tuner in the set is bad (channels 2 - 6 are low band of tuner) or you have a loose fitting on the cable connection that goes to the set.
A way to get around would be to use a cable box that has audio video outputs and connect to a set on your tv--go to that input and change channels with the box--this bypasses the tuner in the set.
Apr 10, 2012 | Sanyo DP19648 19 in. LCD TV
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
I have a 47'' phillips lcd flat screen,will my tuner work without using cable box(timewarner) and still pickup all the channels
If the TV tuner has digital connection with HDMI, or th white red and yellow connectors for RCA cable, it will work with the new TV.
If the tuner has only coax round antenna-like connector, then it will not work with TV tuner.
Many new TV also do not have scart cable connector, but adapters Scart to RCA are available.
May 05, 2009 | Philips Televison & Video
Tv coax f connecter is broke off cannot hook cable cord on it. or antenna
I looked up the manual for this TV and it has composite (RED, WHITE, YELLOW) and component (RED, GREEN, BLUE) connectors as well.
Are you using a cable or Dish box? If so, those boxes usually have output in Coax, Composite, and Component formats. You could just run that type of cable. If you use Component you will also need another cable set (RED, WHITE) for audio.
If, on the other hand, you do not have a cable box and you are using your TV's tuner you only have two options. You can repair the broken connector or you can route the Coax through an inexpensive VCR which will allow you to convert it to Composite cables. In this case, however, you'll have to use the tuner in the VCR, not the tuner in the TV to change the channel. Sorry it's not the best of news.
I want you to know that I'm not paid for this. It's a strange hobby I know, but I like to help when I can. While I cannot physically repair you TV, I hope you've found this information at least helpful and will rate it positively. If you have more questions please don't hesitate to ask. Thanks, and good luck.
Jan 03, 2008 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
