Question about Texas Instruments TI-83 Plus Silver Edition Calculator
Problem graphing.. I understand that I can type in multiple equations, say for y1, y2, y3... BUT, they won't all graph..only one will graph, then I have to press "Y=" again and highlight the next graph, and when this is graphed, the previous one is not graphed anymore. When I press "Y=", to the left of the y1, y2, y3, etc, there is not a " \ " or anything like that.. There is a triangle pointing to the right, like this " >" but solid, and i can press "enter" to change it to " >> ", or " >| " . It used to be a " \ " but something has happened with the settings..How do i get it back to normal?? Again, I UNDERSTAND that I can put multiple equations under Y1, Y2, Y3, etc and graph them all at the same time! My problem is my settings which are not allowing me to do so!
  • Texas Instru... Master
  • 7,993 Answers
This is my last post. It seems that I squanderd my time for zilch. There is a simple way to reset the defaults or the RAM. I stopped suggesting it because ..(what is the point?).
Press [2nd][MEM][7:Reset][1:All Ram][2:Yes] [ENTER]. Message RAM cleared is displayed on screen. Press [CLEAR] key. Screen should clear the message.
If that does not solve your problem..
Posted on Oct 07, 2009
  • k24674 Dec 29, 2009
    This behavior is characteristic of the Transform application for
    dynamic graphing. It draws a family of curves for different values of a
    parameter.
    When it is used it takes over the graphing from the
    native OS. Since it is designed to draw many similar curves, only one
    function can be activated in the Y= editor screen. The change of the
    value of a parameter will generate several curves and no place is left
    for the other Y= function.
    To recover the normal graphing, Transform must be unloaded from memory.
    To do so
    1. Press the Apps button.
    2. Scroll down to select Transform
    3. Select it and press ENTER.
    4. A screen with title Transform Running appears.
    5. You will be prompted to continue or uninstall the APP (may be QUIT).
    6. Select the option to Uninstall (It will not delete it, just unload it from memory)
Program to graph shaded heart
What are the question marks in the two equations? Get rid of them or replace them with numbers and you'll get rid of the error.
Apr 28, 2012 | Texas Instruments TI-83 Plus Graphing...
I have a student in my Precalculus class who is trying to graph several equations simultaneously, and her calculator will only display the graph of one equation at a time. In the equation editor, the...
Some time or other she played with the Transfrm Application. It remains in memory and takes over the graphing capabilities of the native OS. It must be kicked out of memory.
  1. Press [APPS]
  2. Use Up or Down arrows (Up is faster) to get to the bottom of the APPS list.
  3. Locate [:Transfrm], highlight it and press [ENTER]
  4. In subsequent screen, select the [UNINSTALL] option.
  5. Go back to the [Y=] screen and enter or edit your functions.
  6. Press [GRAPH] when finished entering the functions.
Oct 07, 2010 | Texas Instruments TI-84 Plus Calculator
When i press Y= button and graph quadratic equations the graphs are not accurate i realized that the symbols to the left of Y1 Y2 Y3... Are different they are no longer lines greater than less than etc....
In the Y= editor, scroll down to the equation in question. Press left-arrow until the cursor goes over the symbol. Press ENTER repeatedly to cycle through the various graphing options.
Jun 24, 2010 | Texas Instruments TI-84 Plus Silver...
I use the Y= key and type in my two equations, then i hit the graph button and it doesn't show up, why won't it graph for me?
Once you enter an equation the corresponding equal sign is highlighted by default. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted. If one is not highlighted, move the cursor on it and press ENTER.
If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER]
Command PlotsOff echoes on main screen. Press [ENTER], screen displays Done.
If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
You shouild make it a habit to clear the RAM every time you start a new type of problem.
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-84 Plus Calculator
Graphing function will only graph one equation at a time. Why is this and how can I fix it? Thanks!
  1. Once you enter an equation, the corresponding equal sign is highlighted by default.
  2. Before you draw the 2 graphs, move the cursor to Y3 or Y4 and verify that the = signs for Y1 and Y2 remain highlighted.
  3. If one is not highlighted, move the cursor on it and press ENTER.
  4. If you still have problem, press [2nd][STATPLOTS][4: PlotsOff] [ENTER].
  5. Command PlotsOff echoes on main screen.
  6. Press [ENTER], screen displays Done.
  7. Restart the graphing procedure.
  8. If all else fails, just reset the RAM by pressing [2nd][MEM][7:Reset][1:All RAM][2:Reset], press [CLEAR] to clear the message.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-84 Plus Calculator
How can I graph two equations at once? My equal sign will not stay highlighted for two equations. It just graphs one at a time
Hope it helps.
Oct 14, 2009 | Texas Instruments TI-84 Plus Silver...
I can't graph more than one equation in the y= area of my Ti 84+
The marking that so puzzle you define the type of line (or dots) to represent the graphs. Enter as many functions as there are Y variables.
After entering a function press [ENTER] to jump to the next one.
When finished entering all functions press GRAPH. If you want graphs drawn one after the other, in MODE highlight Sequential (6th line) and press ENTER. If you want graphs drawn simultaneously, in MODE (6th line) highlight Simul and press ENTER. Press 2ND QUIT to return to previous screen . Execute graph again.
Hope itr helps.
Sep 23, 2009 | Texas Instruments TI-83 Plus Silver...
I can't see two graphics simultaneously.I write Y1= (something) and then i write another function Y2= (something). But when I click "enter" in the = sign of the second function, the black spot jumps to the...
To view both graphs, the = signs on both y1 and y2 must be contained in black boxes. If you put your cursor over the = sign on the second equation and hit enter, it turns that graph off and you won't be able to see anything but the equation in y1 line. If there is not black box around the = sign of any equation in any of the lines you have typed an equation into, you will not see the graph.
Aug 12, 2009 | Texas Instruments TI-84 Plus Calculator
How to determine function in terms of coordinates
It depends on how complex the function is; there are different techniques. For a straight line of the standard form, usually shown as y=mx+b; this is a simple function of y in terms of x. So, determining the function in this case means finding values for m and b. --- m is the slope of the line, commonly called rise over run. Since your question asks in terms of coordinates, I would assume that you are looking at a problem giving you 2 points.
Probably something like p1 = (3,4); p2 = (5,8); the general form of this is p1=(x1,y1); p2=(x2,y2). The slope in this case is rise over run, in other words, the change in y divided by the change in x. This can be calculate between these two points as (y2-y1)/(x2-x1). In my sample above, this would be (8-4)/(5-3) = 4/2 = 2 giving the value of m.
To find the value of b (the y intercept) you need the value of y when x = 0. Since you already know that m, the slope is 2, consider a new point, call it p3 (x3,y3), pick either of the known points and solve the slope equation again, this time for y3. [m=(y3-y1)/(x3-x1)]. We know that x3 is 0, since we are trying to solve for y where that is true, so the equation becomes:
m=(y3-y1)/(-x1)
-x1*m=y3-y1
y3=y1-x1*m
y3 is really b in the standard form, since it is, by definition the intercept, or the value when x=0,
so
b=y1-x1*m -- this gives you the y intercept anytime you know the slope and one point on the line.
In the example, y1 = 4, x1=3 and we've already calculated m to be 2, so
b=4-3*2 = -2
So, the function would be
y = 2x -2
To check, plug in the values of the other point, p2, and see if they work
y2 = 2*x2 - 2
8=2*5-2
It's easier than it looks. It can help you to understand if you get some old fashioned graph paper and plot it so you can see what is happening.
Jun 16, 2009 | Computers & Internet
My calculator will only graph one graph at a time.
This is simple... Back up all RAM, (press second+, then 2, then 1, press enter to back up something if backed up it will have a star by it) Then clear your RAM (pull out your batteries while the calc is still on or press second+, then 7, then 1)
Hope this helps!
Oct 07, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Silver Edition Calculator Logo
233 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
