Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Push on power and it won`t power up. - Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
  • geneperreaul Oct 09, 2009
    I was going to repair it my self.i was wondering if it was the inverter or something esle like maybe the power switck went bad.
    Scholar:
  • 98 Answers
Have to call Dell for the replacement if your Dell monitor still no warranty. If not have to buy a new one.
Posted on Oct 06, 2009
Testimonial: "you mean i can`t get parts for it "
  • 1 more comment
  • Nathan Ramojal Oct 08, 2009
    That's difficult having issue with the monitors. Regarding the part/s I am not sure if there is available, but perhaps though. If you will take the monitor to the repair shop they will charge you more and there is a big possibility that the issue will re-occur again.
    Thanks.
  • Nathan Ramojal Oct 09, 2009
    Actually you can by going to the repair shop. But my concern is that, once the monitor is being teardowned it could be easy to be broke again. Again as what I mention if your monitor still under warranty better to call DELL for replacement. Thank you.
  • pm_ncc1701 Oct 22, 2010
    Here is a site that might help http://www.lcdrepair.us/1704fpt-1905fp-l...
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
My sharp aquos won't power on
CHANGE IC202 WITH TL431 OR TRY PUSH INPUT AND VOLUME DOWN THEN PLUG THE POWER UNTIL THE GREEN LIGHT START ,,, WHEN IT START PUSH VOL DOWN AND CHANNEL DOWN AT THE SAME TIME AND PLAY WITH THE SETTING
Apr 20, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Amplifier gets power but won't push my subs
check - and + wires then make sure that all ohm and watts are in the same range od the subs and amp
Feb 08, 2013 | Audio Players & Recorders
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My lawnmower won,t start
Three things I know to check. 1. check for broken kill switch wire or loose connection on same wire. 2. check for loose or corroded wires on switch. 3.If this unit has a stator and mag polish the surfaces of both and check clearances.
Jun 21, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Mitsubishi tv won't turn on
did you try new batteries in the remote? if the tv has buttons on the side and one of them being power di you try to push that? did you push tv power or cable power holding the buttons longer? those things might work.
Jun 05, 2012 | Mitsubishi WS-55909 55" Rear Projection...
Bernina 1130 power cord won't retract
since the machine is a bernina, the machine probably needs to
be checked at a sewing machine shop, to see why the power
cord won't retract
Jun 03, 2012 | Bernina Sewing Machines
My msntv2 won't power up. A green screen comes up and says refer to error code #131.
I got the same problem a few days ago error#131 on my msntv2 unit. Tech support at msn said to start with the power on ---then push and hold (alt) and push power and release both at the same time and the power should shut off.--- Then push and release Power and Immediately push and hold down (alt.)---Then a Orange light should come on---Then release the (alt) key--- then enter 5532 5532. If that does'nt work then try starting with the power off---Then push the OK button 3 times then push 5532 5532. Mine didnt work so I dont know what happens after that. Good luck
Apr 30, 2012 | RCA MSN TV 2 Digital Media Streamer...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Open Questions:
See all Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Questions
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
534 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
