Question about Panasonic PT-43LC14 43" Rear Projection HDTV
I dont have a pip button on my remote to reset my
I don't have a (pip) button on my remote to reset my lamp meter.Is there another way to reset the lamp meter without the (pip) button?
    Problem Solver:
  • 10 Answers
If you do not have the (PIP) button on your remote look for for the (split) button and try the volume down and (PIP/split) trick again. it worked for me!! good luck..
Posted on Oct 08, 2009
What if u dont have the remote to reset the timer? Can u reset the lamp hour meter right from the controls on the tv?
You must have the Remote Hand unit to reset the lamp timer in a Panasonic LCD Rear Projector.
Here is Panasonic Lamp reset for all models.
VOLUME DOWN button on the TV front controls
and
a. SPLIT,
Or
b. PIP/VTR button
Or
c. MUTE
on the remote together for over 5 seconds
Depends on remote control, 3 different types.
Robert
Calgary Big Screen In Home TV Repair Service
Oct 19, 2015 | Panasonic Televison & Video
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
WHEN I TURN IT ON A BLUE SCREEN SAYS TO RESET THE LAMP HOUR METER OR REPLACE THE LAMP. IT HAS A NEW LAMP . HOW DO I RESET THE HOUR METER?
hello Plug the power cord back into a properly grounded wall outlet. Then press the POWER button on the projection display or the
remote control to turn the power on
simultaneously for more than 5 seconds.
When the lamp time reset procedure is complete, the
above screen will appear. (This screen may be different from
the actual screen.)
Note: When the lamp time reset is complete, the LAMP
indicator goes out. i hope it helps
regards
shaun
Jan 15, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Lamp reset
This also works for the Panasonic PT-61LCX65. You hold the volume button down on the projection display, then hold down the Split/ DVD button on the remote control at the same time. I just did it after reading the advice posted. Thank you!
Oct 11, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
1,010 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
