Question about Garden
Purchased second hand troy bilt ts525cswith no manual. need to know how to get the spool out...to restring
5 Suggested Answers
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Posted on Apr 05, 2010
  • 391 Answers
SOURCE: How do I open the spool to restring a Troy Bult
They come with a rig pin to lock the spool in place, then turn the large platic ball on the bottom of the trimmer head COUNTER CLOCKWISE. do not try to fill up the spool with line it will only get stuck and melt together. You should also sprinkle the line with baby powder as you wind it up as it reduces sticking too.
Posted on May 27, 2010
jyackle5
  • 8197 Answers
SOURCE: Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
Posted on Jun 27, 2010
woobie dog
  • 1273 Answers
SOURCE: I need to know directions
Try this link:
http://www.fixya.com/support/r2827867-winding_line_trimmers
It is full of information.
Best regards, --W/D--
Posted on Jun 02, 2011
How do you restring the line on the spool? I can't get the spool off but have managed to rethread it. Just can't figure out which direction the line should be wound.
there should be screws in the corners/middle at the back of the head. Phillips/torx head, once they are removed,you can separate the housing and then you will need to wind the the spool counter-clockwise, note the cord is not attached, once you believe you have wound the spool enough, you will need to feed the cord through, tie a knot, burn the end and the let go of the spool and it will retract the cord, pull a couple of times to make sure the knot is holding, then reassemble and start weed eating. Good Luck Tim
Apr 23, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Good Luck
Jun 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do I open the spool to restring a Troy Bult line trimmer
May 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
Im rebuilding carb on TB425CS and not sure I put everything in the way it should be is there a diagram I can look at
Plug your model number into the left hand side menu on this page:
MTD/Troy Bilt Replacement Parts
On the parts listing pages that follow, click on the magnifying glass icon to see an exploded, call-out diagram that will give you the details you need. Good luck!
Apr 19, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Describe string replacement Troy- Bilt TB5755SS
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Have weedeater but no manual to read on how to restring to line
to restring it all you have to do is pop the cap of string head pull the spool out and wind your string around it in the way they say to run it.its usually on the spool wind this way with an arrow.the cap shood be pushed in and turned to unlock the cap replaces the same way
Jun 10, 2009 | Troy Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
