Question about NRS 1.5 Hp 3450rpm 56J Frame 115/230 Volts Energy Efficient Swimming Pool Pump Motor Service Factor 1.30 Ao Smith Electric Motor # ST1152
Need help wiring reverisable 115 volt motor . my switch is a 3 position toggle on/off/on, and has 9 taps on back. motor is 1 hp and has 6 taps in it.
    President:
  • 497 Answers
The only way to reverse the movement it to rotate the stator.
Posted on Oct 06, 2009
Old motor wires are numbered new motor wires are colored this is a 1/2 hp reversing motor for a overhead door
Single Phase Terminal Markings Identified By Color: (NEMA Standards) 1-Blue 5-Black P1-No color assigned 2-White 6-No color assigned P2-Brown 3-Orange 7-No color assigned 4-Yellow 8-Red
Mar 02, 2014 | Computers & Internet
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
110 volt
see side of motor for schematic take off back either turn knob to 110 volts or you have to switch the brown wire to a different lug and the white wire to lug #2 then the black or colored wire goes to #1 and white goes to #2 green to ground
Jul 25, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Pool motor factory wired for 230v.need to change to 115v
take off back panel of motor if a switch turn to 115 volts or 120 volts what ever choice they give you if no switch see side of motor it will show you on low voltage to move the brown and white wires
Apr 27, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Need wiring schematic for a 115 volt install
THERE ARE THREE SCREWS 1 AT ONE O-CLOCK(GOUND) THE OTHER 2 AT THREE O-CLOCK.ARE THE LINES(POWER). THE CAN GO ETHER WAY ! YOU WILL NEED TO SET THE SWITCH OR WIRES TO 115 V POSITIONmotorwizj_0.jpg LOOK ON THE MOTOR LABEL IT TELLS YOU HOW TO SET IT UP . HOPE THIS WAS OF HELP. IF IT WAS CLICK ON THE YES HELPFUL BUTTON .. THNX... JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 13, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
I need a replacement toggle switch for a chipper/shredder.The 1/12 hp motor experiences frequent slow downs, depending on what is being chopped. Sometimes it even stops momentarily, I presume causing...
My friend did a pretty good search for similar toggle
1) He found a 'wall-type' 30Amp DPDT at Global
2) He said he couldn't find others ... but the internet changes.
3) This switch could be mounted in a box that screws to side of chipper. Switch will work fine with 125V.
4) Radio shack and the automotive stores carry 5 amp versions of the DPDT, but they burn up like you said
5) Here is wiring schematic for switch schematic
6) Note: Wiring is different than automotive-type DPDT toggles where power connects to center pole and loads connect to outside poles
-Power on global DPDT connects to poles L1 and L2
-L1 switches to A1 & B1 ... while L2 switches to A2 & B2.
-Poles L1=>A1 and L2=>A2 turn on-and-off at same time
7) In a reverse of the schematic shown above, my friend is using the global switch on 30Amp water heater to switch voltages between 120 and 240 so we know switch can handle the amperage. schematic
Sep 30, 2010 | RTO 30 Amp Dpdt 3 Position On-off-on...
Breaker keeps tripping when turning on pump.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
May 16, 2010 | AO Smith 1 HP 115/230V 56C Replacement...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
NRS 1.5 Hp 3450rpm 56J Frame 115/230 Volts Energy Efficient Swimming Pool Pump Motor Service Factor 1.30 Ao Smith Electric Motor # ST1152 Logo
379 people viewed this question
Top NRS Plumbing Experts
Donni Steen
Tom Chichester
Are you a NRS Plumbing Expert? Answer questions, earn points and help others
