Question about Singer 3116 Simple
Singer 7444 won't wind the bobbin
When I push the foot pedle, the machine starts to wind the bobbin for 2 second, the it stops, starts to beep and flashes on the stitch number window with 88 on it, the needle doesn't go in stop mode when my winder is pushed to the far right. I did everything by the manual, it doesn't work! Someone else had this problem back in December 2008 but there were no solutions. Please help!?
2 Suggested Answers
nenndre
SOURCE: Singer 7444 won't wind the bobbin... please help...
I guess the machine was defective, i trade it to the new one, and the bobbin worked fine...
Posted on Dec 27, 2008
Singer 7444. Can't use button hole. I have
try changing the needle
clean under the needle plate and in the bobbin area
and make sure you use every thread guide
Aug 11, 2013 | Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
Bobbin
To insert a filled bobbin, lift the presser foot and turn the hand wheel to put the needle at the highest point. Slide open the face plate and drop in the bobbin with the two holes up. Pull the thread into the groove near the center front of the bobbin opening and then to the left (another groove). Then pull it to the back of the machine and close the face plate.
To wind a bobbin, you will need to unthread the machine most of the way. Leave the the thread through first and second thread guides. Then bring the thread around the bobbin winding disc (so that it goes under and around the disc) back towards the bobbin pin (on the top right of the machine). Pull the thread through the correct hole in the bobbin (the one away from the center of the bobbin). Leave a 4" tail. Push the bobbin onto the pin and then push the bobbin and pin as far to the right as it will go. Hold onto the thread tail and step on the presser foot to start winding. After ~10 winds, temporarily stop winding and cut the thread tail. Then step on the presser foot and complete winding. When done, cut the thread to separate the bobbin from the top thread. Rethread the top thread and insert your bobbin.
The manual for the 4228 is available here: http://www.singerco.com/uploads/download/492_4228_4220_030707_new.pdf . See page 31 (18 of the pdf) for pictures of threading and winding the bobbin.
I hope this helps.
Jan 19, 2012 | Singer Inspiration 4228 Mechanical Sewing...
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
Singer Touchtronic 2000 - it will not wind a bobbin, I have found a manual onlin that says you just drop it in and push the foot feed and it will wind the bobbin but it doesn't do anything.
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
Oct 24, 2010 | Singer Sewing Machines
Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Feb 28, 2009 | Singer 3116 Simple
Dec 26, 2008 | Singer 7444 Mechanical Sewing Machine
Singer 3116 Simple Logo
97 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
