Question about Texas Instruments TI-30XA Calculator
How do i put somthing to the 48 power - Texas Instruments TI-30XA Calculator
  • Texas Instru... Master
  • 8,064 Answers
Use the raise to a power key. It looks like a caret [^] (or accent circonflexe). On certain calculators it is an [X raised to y], or [Y raised to x] 4 to power 48 is entered as
4[^] 48 [=] result is 7.922816251 28
Hope it helps.
Posted on Oct 06, 2009
How do you do long division
Let's do an example, outlining all the steps.
528 divided by 6
__88
6)528 does 6 go into 5. How many times does 6 go into 52. So put
48 the 8 above the 2. Next multiply 8 times 6 and put the answer
---- under the 52. Subtract 48 from 52. Write the 4 under the 8 in
48 48. Now bring down the 8 from the 528. How many
48 times does 6 go into 48. 8 times. Write the 8 above the 8
--- in 528. Multiply 6 by 8 and write the answer under 48, and
0 subtract from 48 leaving 0.
Let's check to see if we did it correctly. Does 88 times 6 equal 528? Yes. So we have confirmed that we did it correctly.
Good luck.
Paul
Oct 04, 2014 | Office Equipment & Supplies
The battery has been replaced but the battery still loses power and runs down once its turned off
it sounds like you have somthing staying powered up hook up battery negitive cable and then use test light on positive lead put clamp on battery positive lead and use the point on the battery if light is on bright then you have somthing staying on like glove light dome lights or even visor lights with lead still hooked up you need to touch the clamp to the point end to power down the timer system usually 20 seconds then pull clamp away from point end while staying connected with battery and cable if you loose that connection you will need to start timer power down again then while someone is keeping the connection pull one fuse at a time and notice if light goes out or dim if it does either then see what that fuse powers and it will tell you what is staying powered
Aug 17, 2013 | 1999 Ford Explorer
My mixer wont power up. the only light that comes on is red led +48 v
This MAY be a power supply problem. We need to find if the power supply is putting out what it is supposed to. Using a meter, put one probe in pin 1 (ground) of one of the mic connectors, say channel1. Put the other probe in either pin 2 or 3 of another mic connector... Note we are using different connectors as there often isn't enough clearance for the probes in the same one... With Phantom power turned on and LED +48 lit, how much voltage do you read? If it is say 40 volts or more, then power supply is operating.
If the supply is operating then a POSSIBLE problem is a connector has fallen off where it connects to the supply or the main board.
The power supply provides several voltages such as 5 volts, 12 volts and 15 volts of various polarity.
If the 48 volt supply is found to be operating with the above test, then since the switcher and transformer are shared, it is likely the other voltages are available.
CAREFULLY open the unit and look for a loose cable.
PLEASE NOTE: This is a switching type power supply and part of the supply runs at power line potential. Only work on the supply if you are skilled and have an isolation transformer for your own safety.
Sep 21, 2010 | Behringer XENYX 2442FX Mixer
I dropped my centro into water & will not power
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Dec 07, 2009 | Palm Treo 500 Centro
Why does water constantly flow out of the backwash, even if the filter is on "filter"
You have sand or somthing stuck in you spider gaskit.
Take apart and clean.
OR
Move handle around and hope it will dis-lodge iteam.
Be-careful not to damage spider gaskit 'O' ring.
Jul 11, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
System does not work
try update cd,,,, i might work..
if its hard drive normally says error code, might be somthing like mother board...
Sep 22, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Powers on 5 sec then powers off
if it goes off even with no sound, system is put on stndby protection mode. something wrong with your output section. busted power output xtors of IC.
Mar 17, 2008 | Audio Players & Recorders
Texas Instruments TI-30XA Calculator Logo
1,286 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
