Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Power on get a rattle from the middle of the back of the TV. The TV will not power on and the status light flashes red.
  • 115 Answers
If your little rattle lasts for just a couple seconds then goes away and it happens three times about 30 seconds apart ,after you press power . then replace the lamp.
Posted on Oct 14, 2009
  • 556 Answers
TAKE THE BACK OFF, GET YOUSELF A CAN OF AIR AND SPRAY OUT THE FANS, BE SURE TO UNPLUG IT FIRST.
Posted on Oct 07, 2009
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Jul 17, 2012 | Televison & Video
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv turns on briefly then goes out with red flashing status light
This is exactly intermitent problem, It needs to be trouble shoot at the repair shop if the problems occurs from power supply or high voltage.It needs a lot of test and equuipement to be accurate.And also the specific parts.
r_ic7
Nov 28, 2008 | Mitsubishi Televison & Video
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 Red Status Light After Cap Replacement
A steady red light: there is a short on the DVI cable from FMT to DMD disconnected
Sep 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Red light flashes no picture or sound. Likely causes?
did your TV just cut off in the middle of watching it and it want come back on. My red light beside the power button flashes also.
May 06, 2008 | Toshiba 50H81 50" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
