Question about T-Mobile Wing™ Smartphone
Tmobile wing camera, not opening
I just bought a Wing today and everything on it, so far, works..except for the camera. Ive pressed the camera button on the outside of the phone and ive also tried getting to it through the start menu but to no avail. Can someone help? what can i do to get it to open?
I have the same problem but my camera starts and opens. but it shows message "not enough memory, close other programs and try again." I have gone through everything. I have also freedup the memory byclosing every program. It still says the same!
Posted on Apr 09, 2008
  • 97 Answers
Your are doing everything right......if its not a software issue, you might need to return the phone and get another one. you are still within buyers remourse. if you want to try and fix it, try just taking the batter out or doing a master reset by goign through start, settings, system, clear storage. it will delete the infor not stored on the sim or media card
Posted on Jan 01, 2008
T-mobile wing - will they work together ideally
Yes, it does, for calls, phonebook, and data. I just upgraded from the tmobile Wing to the tmobile Touch Pro 2 which does not work for data on the tom tom 930T. If you have a problem still try the Xda-developers site look in the HTC Herald forum that is the HTC name for the Wing same phone... and get a custom rom for your phone.
May 03, 2009 | GPS
Tmobile wing frozen
Turn off your mobile and then pull out the storage card, Restart your device, it should work now !!!
Jan 10, 2009 | T-Mobile Wing™ Smartphone
Tmobile wing won't turn on the wifi
I had the same problem with my htc mda vario. I had to hard reset the phone and it'd work just fine for me . I have not had that problem yet on the wing
Dec 25, 2008 | T-Mobile Wing™ Smartphone
My tmobile wing keeps freezing up when I try and text
It took me a long *** time to fix my wing, but this is the only way i found. shout out to my homie muhammed for showing me:
hold both left and right toggle button simultaneously, and use stick to press the reset button. continue to hold buttons....
it will reformat. press send to wipe the phone.
then, use active sync to completely wipe the micro sd memory card once wipe is complete
this will delete the static charge virus
lastly, go to tmobile website and download the rom software upgrade.
reconnect the wing to your pc
charge the phone past 50%
click on the new software upgrade icon and follow instructions.
the screen will show 3 lines, green red and blue with the new upgrade version numbers.
once complete, you have completely upgraded the tmobile wing to the fullest extent
if this does not work, then sadly enough.... your problem is from dropping your phone too many times and causing the components to become loose connections. aka the sliding keyboard.
i also noticed that the only thing stopping the keyboard from stopping is a tiny square piece of plastic. but then again, this phone was crafted in china. chinese plastic isn't the most sturdy composite material.
Dec 01, 2008 | T-Mobile Wing™ Smartphone
Tmobile wing screen searching for SD card
ok first you need microsoft sync on your pc second you need to download the wing update from t mobile it will walk you through the process the bars you are seeing means it is in flashing mode this software will fix the problem any questions e mail me at
Oct 05, 2008 | T-Mobile Wing™ Smartphone
Slow Responses
Do a backup with PIM Backup and them hard reset the phone (Factory default)
To hard reset the wing: Hold both soft keys down while hitting the reset button with your stylus (the little hole on the side). Should bring up a black screen with some text. Press "send" key to finish process.
*Note it takes a couple of tries to get all of the buttons pressed together. May not work first try.
Aug 14, 2008 | T-Mobile Wing™ Smartphone
Tmobile wing..
Hi Samantha
Try and do a soft reset for your device by pressing the reset button on the side of the device "It's a small hole just below the volume slider. You can press it with your stylus pen"
If that doesnt work, you may need to hard reset the device. Note, if u hard reset, you will loose all your data. Make sure you backup all your data before doing a hard reset.
It can be done by holding down the two soft keys on the front of the phone (the soft keys are two buttons with a "-" symbol on them.
To hard reset,hold down the two soft keys on the front of the phone (the soft keys are two buttons with a "-" symbol on them.
Hold those two down, at the same time, while pressing the reset button on the side of the phone. This will erase all data, and restore the phone back to factory condition.
Aug 04, 2008 | T-Mobile Wing™ Smartphone
I have lost a button on my wing phone ( the button under the talk button)
I have had the same issue twice now, both times I was able to buy replacement buttons on e bay for about 10 dollars, however there is no instructions, and I think it was my fault it broke the second time because they are so delicate and difficult to replace without breaking a clip. However they are cheap and easy to find on e bay if you wanna chance the repair yourself!!
Mar 02, 2008 | T-Mobile Wing™ Smartphone
Wing Touch Screen stopped working
call tmobile and ask for a hanset exchange if it hasnt been a year since you bought it then they'll prbally give you a new free one
Nov 01, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
56 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
