Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
When I turn on the power the speakers pop for about 30 seconds and then the power light blinks but the screen stays blank
2 Suggested Answers
  • 147 Answers
SOURCE: Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Posted on Apr 09, 2009
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pioneer GM-7200M power problem
Check your GROUND wire might be touching something and making bad contact.
Jun 09, 2009 | Pioneer GM-7200M Car Audio Amplifier
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
19 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
