Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
Ac doesent blow air
It wont blow any air but it turns on. i checked the fan and it isn't blocked i dont know what the problem is can some one help me
  • 6,927 Answers
If the fan is not working,then the fan motor is bad,or the start capacitor is bad.Pull the unit out so you can work on it,near the plug in.Be carefull,and use a stick,backscratcher,or something like that.Turn the ac on to cool,high blower,and turn the fan bladeclockwise to see if it will try to start turning on it`s own.Careful not to gouge the coils,and try to turn the fan reall good.If it starts,let it run,for about 15 minutes.If the fan,does not quit,then replace the start capacitor.If the fan wont start turning on it`s own,or the fan stops after a while,replace the fan motor.I hope this was some help.
Posted on Oct 06, 2009
Ac fan wont blow
I would disconnect the fan connector and use contact cleaner to clean the connection. Usually corrosion. Also fan might be going bad (Common Problem).
Mar 27, 2013 | 2000 Saturn L-Series
When i turn on the ac no air blows throw
Go to the fuse block and check 15A fuse D which feeds power to the blower motor. Then check 10A fuse K which feeds power to the blower relay and the fan (blower) speed select relays. If the fuses check OK, the blower relay, the fan switch or the speed control relays may be defective. also, the fan speed resistor may be defective
Oct 17, 2012 | 1993 Nissan Pathfinder
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
My ac unit was working just fine then got where it was barely blowing on level 4 and then now today wont blow at all and even heat wont work no air will come out
Check the blower resistor block( that controls the speed and powers the fan blower ), u can locate it under the dash in the side of blower housing( usually u have to remove the glove compartment ). Check the continuity of the connection, if broken, u have to replace the whole resistor block.
Hope that helps u out!
Jun 12, 2011 | 2001 Chevrolet Cavalier
1989 cougar heater or ac wont blow air what could be the problem
Its either the fan switch is bad,,or a fuse,,or the fan motor its self is bad,I would check fuse 1st,,2nd unplug fan motor run a hotwire to it and see if it turns,,if it does than you know its the switch for the fan. If it dont turn with separate hot wire ,,than its the fan go bad.
Mar 07, 2011 | 1989 Mercury Cougar
I have a problem with my air conditioner in my 2001 ford explorer
If cold air is coming out in the back seat then your compressor and the rest of the system that circulates the freon is working. When you turn on the A/C for the front do you hear the fan come on? If so and if no air at all comes out the front then you might have an air valve stuck or a blocked air duct. I don't know how extensive the damage was from your crash. If you cannot hear the fan start when only the front A/C is activated then you have some kind of electrical problem.
Nov 03, 2017 | 1999 Ford Explorer
My 2003 gmc sierra wont blow any air out of the vents
check for 12 V and ground at blower motor with the fan switch at high if o.k replace motorand if you12V but no ground replace fan switch .good luck
Jan 28, 2009 | 2003 GMC Sierra
It simply wont turn on
a thought is , exactly what wont turn on? the indoor blower? the outdoor fan or the outdoor compressor?. be specific for goodness sakes. i assume you mean the ac wont turn on since its cold here in fla. dont know where you are since you didnt say. if it blows but not cold then outdoor unit is problem. if air out side being discharged is cool then compressor isnt running. check caps and volts through contactor. if ok check power directly into compressor. if ok the look at amps etc.
Oct 15, 2008 | Electrolux Heating & Cooling
My ac
the second fan shuold work on and of not all the time and you probably need some more ac frion in your system.
Jun 11, 2008 | 1996 Nissan Sentra
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
418 people viewed this question
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
