Question about Refrigerators
Our Dometic refrigerator has a very strong smell in the freezer compartment. It smells like strong men's after shave or cologne. We bought the travel trailer new. The guy wreaked of aftershave/cologne. I just kept my distance. When we got it home and started cleaning up the trailer, I noticed the smell. Smelled a lot like that guy, but that was a day or two previous. I washed the door and especially the gasket where it seemed to be coming from. Soaked it in vinegar. Washed with baking soda. Washed with bathroom cleaner. I tried everything - several days apart. The smell comes out of the back, too when it is running. Presumably the exhaust fan or something is pushing it out. It is not an ammonia smell. Otherwise, the fridge runs OK. Any ideas?
    Problem Solver:
  • 7 Answers
Gas is leaking the compelet piping control is nessecery
Posted on Oct 11, 2009
2011 Kenmore French Door Refrigerator smells like men's cologne
The best de-odorizer is baking soda left open in the refrigerator. Gas leaks are not mistaken for cologne.
Dec 08, 2013 | Kenmore Refrigerators
Which if any colognes smell similar to Tuscany for men?
According to a lot of popular perfume and cologne sites the top similar scents (due to the woodsy and slightly citrus scents) are Nobile, Pino Silvestre, Pierre Cardin, Carlo Corinto, and Mediterraneum. All scents have a similar lifespan as Tuscany too, falling between 6-10 hours.
Jul 23, 2011 | Tuscany Cologne Tuscany; for Men
Had a strong Amonia smell. Fridge wants to turn on but no cooling.
Strong Ammonia smell is dead give away for LEAK. Ammonia is the chief ingredient in the absorption type cooing system. Probably not economical to repair. For a second opinion, contact a Dometic Authorized Service Center.
Thanks for your question @ FixYa.com
May 31, 2011 | Dometic NDR 1292 Refrigerator
I have a Dometic Rm 2862 2-way about five years old.
Ammonia smell means cooling unit is done. Just double check on dometic site in case of any recalls that may apply. (dometicusa.com)
May 24, 2010 | Dometic RM2852 Refrigerator
I can smell items in my freezer when I open the door of the fridg
Good day,
All cooling in a refrigerator, be it the freezer section, or the fresh food section is performed by the freezer.
The freezer takes care of itself, but also by the function of the fan motor in the freezer, blows a limited amount of the freezer air into the fresh food compartment to cool it to the nominal 37 degrees.
The odor in the freezer is disguised by the extremely cold air, and is not apparent. But that odor when raised to 35 or 40 degrees will become noticeable.
As well, the freezer compartment rises to 30 degrees plus when going thru it's automatic defrost cycle, which occures for approx. 30 minutes once or twice a day, adding to the problem.
Sealing the packages is probably the only real answer.
Thank you for using FixYa.
Dec 18, 2009 | Kenmore Refrigerators
My Dometic has a very styrong smell of ammonia.
TURN THE REFRIGERATOR OFF AND DO NOT USE!!!!
You have a bad cooling unit. This is the entire assembly on the back of the refrigerator that draws the heat out of the box. You will have to either have the cooling unit replaced or buy a new refrigerator. The cost difference is usually around 200 to 500 depending.
Hope this helps,
Jeff
Jul 06, 2009 | Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Strong burning smell
probably the defrost heater has shorted
Jan 17, 2009 | Whirlpool ET1FHTXM Top Freezer...
Dometic RM761
ammonia smell means the cooling unit is bad and must be replaced.....check out rvmobile.com
Aug 18, 2008 | Dometic RM2652 Refrigerator
Dometic problem
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
May 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
199 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
