Question about Sony KP-57WS500 57" Rear Projection Television
Issues i have red lines in a curve also text will not line up
techman
  • 3130 Answers
SOURCE: Red Curved line
Your first going to need to go to http://www.servicemanuals.net and download a service manual. Look at the schematic diagram, locate the convergence IC's an then order them from http://www.partstore.com Then hopfully you know how to unsolder solid state electronics. If theres a step in here you dont understand, like reading a schemastic, then a TV set is NOT the place to be experimenting around inside of. please seek out a pro to assist you in this repair.
Posted on Sep 12, 2006
SOURCE: Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Posted on Sep 10, 2007
To access the focus block with the screen controls, remove the 2 plugs under the speaker grille. There is a philips head screw under each plug. Remove both screws. the speaker grill is now free. Pull the bottom forward and the grille will come off. The top is just held by tabs behind the screen bezel. Be careful as there is wiring to the grille for video input 2 and the front panel controls. There is a piece of fiberboard held on by 4 screws in the center which was formerly covered by the grille. Remove the screws and the panel and the focus block is right there. Each color is labeled for both screen level and focus. Adjust the screen control of the color producing the lines until the lines just disappear.
Posted on Mar 31, 2008
  • 899 Answers
SOURCE: screen has 3 lines at the top
you need to get a conversion done to correct this problem
Posted on Oct 21, 2008
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Posted on Nov 07, 2008
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
I need to curb the text kind of like word art in corel x4 can you help me to do it or how to do it
To create curved text you need to use the text tool and fit to path. When you create a shape, line or curve and then select the text tool you can make the text take the same path as the object you created by just hovering it over the objects outline, you should see the courser change.
1- Draw the a curve
2- Select the text tool and hover it over the curve that you created and then when the course changes click on the line activating the text tool
3- Type the text
4- Select the curve and change the outlone color to transparent
Jun 10, 2009 | CorelDRAW Graphics Suite X4 for PC...
Curved red lines on the screen and the picture is distorted
This is a convergence problem that can be either poor solder connections on the convergence ICs or defective ICs. If you can solder you can fix this yourself. Update this if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 23, 2009 | Samsung PCL545R 54" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Red text and lines appear in Black text
The red line is indicating a HYPERLINK to the email address of the user name, or other linked text in the Email.
If you are printing a program, you will not be printing anything with a hyperlink, so that should not be an issue.
Apr 27, 2008 | HP PhotoSmart 7660 InkJet Printer
Sony KP-57WS500 57" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
