Question about Muratec Office Equipment & Supplies
Murata Model 1500 Fax Machine
I have been given a Murata Model M1500 fax machine without instructions on how to set up and operate it....
I need site for manual....
Thank you
  • 77 Answers
SOURCE: setup
Although I did not see your particular model listed, you can download the manual for a similar model at: http://welcome.solutions.brother.com/bsc/public/SearchResult.aspx?reg=us&c=us&lang=en&FLG=1&TXT=FAX Setup is pretty similar onn most brother models within the same family Hope it helps Ed
Posted on May 26, 2007
checkitright
  • 1362 Answers
SOURCE: INSTALLATION/OPERATING MANUAL SF3100 phone/fax/printer
here is the manual
http://www.retrevo.com/s/samsung+sf+3100+fax+manual
Posted on Dec 04, 2007
bowdo
  • 78 Answers
SOURCE: Brother Fax 1020
The 1020 only had a hard copy manual (ie not on PDF). The 1020e was rework of the previous model of the 1020 so it should be pretty much the same. Try this link - http://www.remington.com.pg/PDF_files/Brother%20-%20Plain%20Paper%20Faxes/Fax%201020e/Fax%201020e%20User%20Guide.pdf
Posted on Jan 25, 2008
JoshOHoward
  • 63 Answers
SOURCE: SANYO Facsimile manual,free
Ring SANYO OCEANIA on Australia: 1300 728 748 and ask them what you need to know. They will give you answers for free!
Posted on Jan 29, 2008
Logjam
  • 159 Answers
SOURCE: how to use a brother fax- 645 plain paper fax
You may have been given a heap of junk. Happens all the time. Just place the document face down in the ADF and dial the number then press the green button to send.
Posted on Feb 28, 2008
Testimonial: "good and helpful"
Intellifax 4750e phone and fax line stays open, no dial tone
Is the fax machine on? (Are the lights or screen lit up?) Make sure that the line going from the fax machine to the wall jack is plugged into the LINE port on the fax machine, and not the TEL port.
Try plugging a regular phone into the wall jack where the fax machine is currently plugged in... do you get a dialtone? If so, the problem is either with the fax machine or the way it is configured.
May 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax machine rings but fax doesn't come thru at times unless we actually pick up another phone and make a call, at that time the fax comes thru. At other times if we are on the phone, (different from the...
The instruction manuals of fax machines are typically large and complex books. Often there are many options to consider. Mostly the machines can be used successfully without much reference to the manual but when there is a problem the question machine or operator fault can only be determined by thoroughly reading it.
To a large extent whether a fax call is picked up or not depends on the settings (including answering machine), the quality of the phone line and connection and the machine sending the fax as well as the receiving machine.
My fax machine will mostly automatically receive a fax but it seems to miss the important ones and I have to answer the ringing phone, hear the fax tone and press the manual fax button.
I strongly suspect the problem mostly lies with the sending machines - if they are fax machines the results were much better than from a computer being used as a fax machine and while a fax machine will send a receipt, a computer doesn't seem capable of doing so.
Sep 06, 2017 | Brother IntelliFax-4100e Fax
Have a Murata M900 fax machine. Need manual or instructions to make memory dialing work.
The person needing an instruction manual for a Murata M900 fax machine can contact me at loveman@brfinc.com. Put "Murata" in subject line to avoid spam.
Aug 11, 2009 | Muratec Office Equipment & Supplies
How can I turn off the auto answer feature of the pansonic kx fh332. I never want it to pick up and go to fax mode.
Set the fax machine to Telephone mode by pressing
{RECEIVE MODE} until TEL MODE is
displayed.
You might also want to dowload the Operating Instructions for you fax machine: KX-FHD332 Operating Instructions (English) (17208 kb)
Aug 03, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Instruction manual for Brother Fax model 560
Go to www.brother-usa.com.You can download the entire manual. On the Brother site, go to DOWNLOADMANUALS AND PRODUCT DOCUMENTATION, and follow the instructions fordownloading what you need.
Fixya!
Chris (ziraffa)
Jan 11, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Need instructions for fax features
Use the manual AR-F151 it seems to use the same functions as the AR-F152
I set up my fax machine using this manual, and all the instructions worked so far.
Good Luck,
Bob
Jan 05, 2009 | Sharp AR-F152 Fax
Fax problem
Hi Fatimo25,
The screen on your fax machine displays how the machine is set to receive calls. TEL MODE means the machine will not auto-answer incomming calls and will operate as a normal telephone device, it will still however be able to send a fax in this setting.
Place your message on the original tray and pick up the handset, dial the number and when the distant machine answers press the start key or ask for their fax machine and when you hear the high pitched fax tone press start.
There is a button on the panel that will allow you to change the reception mode of your machine to the other settings.
Your machine is of a model that doesn't come into this country so I have no manuals to forward you. You can try however to access the SHARP web site www.sharp.ae
Hope this helps you
regards
Gavin
Oct 08, 2008 | Sharp UX CC500 Plain Paper Thermal...
Setup
May 25, 2007 | Brother IntelliFAX 560 Plain Paper Fax
61 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
