Question about Desa International GWP10 Wall Mounted Panel Heater
How do you hook up the gas line - Desa International GWP10 Wall Mounted Panel Heater
    President:
  • 3,433 Answers
Is there a gas line at the installation location? If you mean where on the heater, Then please tell me why you ask? Isn't it sticking out the side or back? If not, you may have to take a panel off that should have a hole in it and install a fitting to hook the flewable gas line. Its ther and the main gas valve is or should have a open threaded hole the fitting goes into. The flex line come with the fittings.. Good Luck, Ned
Posted on Oct 07, 2009
I just bought a WeberE310 grill and I am unsure how to hook the hose assembly up to my gas line. It appears that I have one threaded connection and one quick connect connection and they won't connect
page 9 .have a licensed plumber hook up gas line and quick connector. the female quick connector is on gas supply and male fitting is hooked to grill.
May 04, 2018 | Grilling
Atv not getti g gas to bowl, new carb petcock lines new gas ?
With the pet **** hooked up and in the open position from tank and vacuum line attached to carburetor and fuel line detached from intake of carb and in clear bottle crank engine. Does fuel go in bottle while cranking. Pour a few drops of fuel into in sparkplug hole reinsert the plug and plug wire to plug hook fuel line back to tank and carb turn on ignition and crank in neutral of course.
Oct 11, 2017 | GAS Motorcycles
Can you advise me on gas connections needed and how to fit connections
I think you are better off going to a Home Depot or Lowes or a plumbing supply house and ask for a gas stove hook-up kit. Then you ask all the questions you need, and ask questions over until you have a good knowledge of what to do and how to do it. There is a great safety factor here, so you need to be clear on how to do the hook up. You can take some pictures of the gas line and of the stove hook up pipe. If you do not have a gas line coming into the kitchen for the stove hook up, then get a qualified technician to install the gas feed.
May 26, 2014 | Cooktops
Dieagram to hook up gas lines 1978 low rider harley davidson 2 peace gas tanks
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson Manuals Mark Workshop
Sep 27, 2012 | Harley Davidson FXDL Dyna Low Rider...
Weedeater, 18cc, replaced fuel line & purge button, the purge button will draw fuel into the fuel line but the purge button will remain colapsed.
You may have accidently hooked the lines to the purge button wrong. The purge button (primer button) should have a short stem and a long stem. The short stem is the suction side of the primer button and should be hooked up to the return on the carburetor. You actually s*uck gas through the carb and not from the tank. The carb should have two hook ups. If you hook the fuel line up to one of the lines on the carb and the button is hard to push and doesn't return to normal, hook the line up to the other one. When you push the primer button gas should be pulled through the carb. The other line on the carb goes back to the fuel tank.80a09a6.jpg
Apr 18, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
How can i split an existing gas line to hook up my dryer? I HAVE A GAS LINE THAT GOES TO MY WATER HEATER AND WOULD LIKE TO SPLIT IT OFF TO HOOK MY DRYER UP BUT CANT FIND A FITTING TO DO THAT
Just put a "TEE" into the line. Make sure you use "BLACK IRON" pipe fittings on gas lines. Galvanized will create problems and you will not only have leaks in the future, galvanized pipe in gas lines is a violation of almost every building code.
Nov 22, 2009 | Kenmore Dryers
Fuel lines inside of tank fell off
This is the typical fuel line routing2.gif on many models: One line ( the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 05, 2009 | Craftsman 25cc Gas Line Trimmer
Diagram on gas tank and lines and how they hook up
I have 5 lines on the gas tank counting the petcock can you tell me were they all go
May 23, 2009 | 1997 Suzuki GSX-R 750 V
Both gas lines are dry rotted off...
Sorry about the delay.
Problem solved, I hooked up the lines (very important to get a drill the size of your new gas line, it aids in sealing the tank, thus providing a good seal for the prime).
The thing in the bottom of the tank, attached to the line is a filter. It is available at any small engine shop).
Once I hooked up the lines and hit the primer ball a few times you can see the fuel moving, you will know, because you will see which way it flows through the lines. The other line is just a return line into the tank.
It is the same on generally any 2 cycle blower or weedwacker motor.
Dec 21, 2008 | Poulan Featherlite Gas Blower, with Low...
Fuel lines
usually there where 3 lines from the gas tank one is the breather,main line,and the reserve line..just try to trace the line
Sep 01, 2008 | 1996 Oldsmobile Achieva
Desa International GWP10 Wall Mounted Panel Heater Logo
134 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
