Question about Corsa Cycling
When starting the car first time it moving very slowly like no power eventhough press the accelator foot all the way down but after a minute or two its working fine. somebody told me its maybe water transmit switch. can some body told me what its wrong and how to repair it. thanks
  • 121 Answers
Sounds like it needs a good service.. Sluggish starts could be a variety of things but fuel jets and air intake are the most likely first thing to check.. Both of which would be done during service..
Posted on Oct 07, 2009
Car starts no power engine size 3.0
Once you press the accel pedal what happens. can you please let me know so I can help you out
No accel at all, is the throttle plate moving if you see inside inlet manifold, does she leak any vacuum, have you check compression ,
let me know
AD
Apr 04, 2014 | 1994 Toyota Camry
1990 Grand Prix starts but doesnt run no power stumbles dies
Could be clog catalytic converter.Tune up fuel filter,coils,air filter.
Apr 02, 2013 | 1990 Pontiac Grand Prix
Car will not accelerate properly
timing issues?? or transmission problems maybe??
Mar 11, 2012 | 2001 Mitsubishi Eclipse
My car is flashin and S3 light and Idk what that means
When the S3 (Transmission) is blinking on the dash, you need to stop trying to start your car and give it a few minutes to chill out. Then turn your key to "on" but without actually starting your car. Put your foot on the break and begin to move your shift up and down slowly. This will insure that you do not have a stick between the engine and the transmission. With the car "on" but not started, continue to move the shifter up and down a few more times. Put it in neutral, with your foot still on the break, and start the engine. This will not work permanently, but will get you from A to B for a little longer. Its most likely the transmission switch failing.
Jan 16, 2011 | 1989 Acura Legend
First gear
The following test is very dangerous. Do not try this if you are going to let the brake go at anytime. YOU MUST HOLD THE BRAKE DOWN WITH YOUR LEFT FOOT 100% OF THE TIME.
OK. Open the hood and turn on the car. Have an assistant stand to the SIDE OF THE ENGINE NOT IN FRONT OF THE CAR. Next, put your foot firmly on the brake with one foot and your second foot on the gas simultaneaouly. Put in gear iff the brake is all the way down. now torque the motor by slowly giving it gas, while you brake NEVER IS UNDONE. Your assitant is looking at you engine to see if it is moving forward and backward erratically. Now torque in reverse gear.
Hold the brake 100% of the time. With the seond foot torque (giving gas) in reverse. You assistant is looking to see if the engine moves erratically.
It sounds like you have a broken engine mount. If a Toyota, there is a "dogbone" looking mount on top of the engine in front of the passenger in the engine compartment. Notice it does not happen when you run lightly, but it noisey when torqued.
Sep 09, 2009 | Cars & Trucks
Trying to us Creative Card
There is an in- between setting. It's not up, but not down either. Does that make sense? If you put the lever up, then bring it down slowly and kind of push it to the back. Hope this helps!
Feb 03, 2008 | PfaFF Creative 7570
It the same problem, needle does not move up and down
The motor is defective. If it's used or older, cleaning the motor with compressed air or vacuum might work if its very dusty.
Oct 29, 2007 | Yamata FY101-1A
Incorrect power management
Dear u have a problem with VGA or Monitor...U should try to put new vga in you'r mother board and try.If still wont work then you have a problem with monitor
Oct 11, 2007 | ASUS P5LD2-VM Motherboard
Cycling Logo
Top Corsa Cycling Experts
John Egan
John Egan
Are you a Corsa Cycling Expert? Answer questions, earn points and help others
