Question about KDS Avitron 195TF Monitor
How do i reset resolution and can I set resolution as low as 1280 x 1064?
  • 8,404 Answers
Control panel, display, settings
Posted on Oct 06, 2009
Screen flashes colors
The issue (flashes" colored screens) you're facing could be related to drivers and could be resolved by updating the display drivers. Without the correct driver, the hardware or device that you want to use won't work properly.
Also refer to:
http://windows.microsoft.com/en-us/windows7/update-a-driver-for-hardware-that-isnt-working-properly
Let's try to boot the computer in low resolution mode and check the issue status.
Low resolution starts Windows using your current video driver and using low resolution and refresh rate settings. You can use this mode to reset your display settings.
Refer the section:
Enable low-resolution video (640×480)
Apr 24, 2014 | Microsoft Inspiron Notebook
No signal to monitor
Change video resolution through video card settings not through windows settings. Windows settings can be changed by software to a video resolution not compatible with monitor. Common issue with TV used as monitor or low end flat screen don't have as many resolution options as pc or video card capable of displaying.accassing video card settings is specic to which brand you have but won't look like rt click screen settings video/ windows settings
Dec 01, 2013 | Computers & Internet
Screen resolution is too big. Unable to correct.
The resolution is set too high, or the icons are too large? If the resolution is too high, the items appear smaller. If the resolution is too low, it gives a "zoomed in" appearance, and everything is much larger.
Has this issue been present since day one, or did it just begin?
What operating system do you have?
Do you have a dedicated (PCI, AGP, PCIe) video card, or are you using the one on your motherboard?
It sounds like you need to update or re-install the drivers for your videocard. They may have become corrupted, and are disallowing your resolution to be set to your desired spec. Many videocards will reset themselves to 800x600 if there is an error with the drivers, making everything seem much larger on the screen.
Oct 06, 2012 | E-Machines eMachines Desktop PC
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
Computer monitor out of range is being flashed on screen
Monitor is not recognizing the resolution settings that are currently set on the computer.
It is probably sett too high.
You will have to lower the computer resolution.
If it is a laptop, you should be able to do this using the laptops screen.
If it is a desktop computer, you either have to use a different screen to reset the resolution.
or
Sometimes restarting the computer while the screen is on will reset the video.
If that doesn't work, try starting the computer in safe mode by tapping the F8 key while it is being started. This will keep the resolution low enough to see it on the monitor and you can adjust the resolution there in the display properties
Oct 19, 2010 | E-Machines eMachines Monitor E15T4
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
The resolution is low
Hi...
Do you know how to change your screen resolution go to "Start / Control Panel, then Switch to view category, then double click display, click settings, change your resolution to 1024x768
Hope it may helpful for you!
Regards
ICmanServer
Jun 30, 2009 | Computers & Internet
Out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
Resolution is low!
Easiest was is go to Camera Menu -> Initialize -> Yes.
Camera will reset and select factory default settings.
Other way is set camera on camera-mode, press menu and find picture resolution setup, you will see fine, standard, vga, email options there, select desired option and done.
Jan 18, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
KDS Avitron 195TF Monitor Logo
90 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
