Question about Toshiba (K000006610) for Satellite P25 Series Motherboard
Toshiba Satellite P25-s526 \r\n
PROBLEM:
When the machine is plugged in and powered off the battery will charge. Then, when the machine is turned on the battery charge light goes off and the power meter indicates the battery is discharging, while at the same time it reports that the machine is on AC power. Ast the machine is used the battery discharges and eventually the machine shuts down.
  • j_n_meadows Oct 06, 2009
    How I wish this would do it,,,,,,,
    I've already replace the battery and changed adapters twice. I've drained the battery (original and new) and charged overnight..... no good... none of it ;>(
    So, given that the battery is fully charged, the machine is powered on, and then the charging light goes out and the machine reports it is both running on AC... AND the battery is discharging ... WTF?
    To make it even worse, if I unplug and then plug in the adapter, the charging light comes on, the flashes a few times and goes out. For as many times as I unplug and plug in the adapter, the same behavior repeats itself.
    President:
  • 2,187 Answers
Try this one first, remove the battery press and hold the"ON" button for at least 30 sec. Put back the battery and the AC adapter and power it on. Try as well to drain the battery completely, unit it does not show any signs of activity then charge it overnight. If that does not work it could be a bad adapter (its not giving the correct voltage) or bad battery.
To test and to avoid purchasing the wrong piece you may want to borrow an adapter and a battery back from someone with a similar laptop. Before testing, have any documents saved and shut down properly. Try using the adapter on you computer and see if it resolves it. If it does it may be a bad adapter if it does not work, you may want to use a different battery. Or you can use your adapter and battery on a known working toshiba. If it works on another laptop yo may have a problem with the port of the power supply or it can be an internal issue.
Posted on Oct 06, 2009
  • Nicolo Carlo Parazo Oct 06, 2009
    This may likely be a problem internally. On the board perhaps.
WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
My Toshiba P25 s526 will power on. The AC is connected. The ac and battery lights are on. The battery discharges and the unit turns off with in 2 min.
Ok take out the battery and plug the AC in and power on to see if it works. If it does then it shouldnt go off after 2 min. but if it doesnt power that means there is a problem with your AC that is why it turns off.
I hope this solution has been helpful.
Sep 26, 2010 | Toshiba P25-S526 Notebook
I need an A/C adapter for my P25-S5262 Satellite laptop. Online sellers keep sending me adapters with a plug that is too small for the power jack. The latest seller wants to know what the "psp number" is...
ah its because at 6 years old the
Toshiba power source and power input plug you seek
has been discontinued and not superseded
A35 19v 6.3a 120w is a rare power source
one on ebay seller USA list this unit suitable for your
Toshiba Satellite P25-S5262
http://www.ebay.com/itm/NEW-Toshiba-Satellite-P25-P15-Laptop-AC-Power-Adapter-Charger-A35-19v-6-3a-120w-/401167479005
if not correct as in picture
you need to keep a look out online for sale any
used P25-S5262 with working power source
Mar 08, 2017 | Toshiba Satellite P25-S5262 Notebook
Windows 7 on Toshiba P25-S526 PC and there drivers
For any drivers not automatically installed with Windows 7 running Windows Update should detect most all of them. You should make sure to select all updates, including optional updates (not the language packs). The optional updates may include hardware updates which will ensure your hardware is using the best and most current software possible. If this does not detect everything, I would recommend going to the toshiba support website and downloading the remainder of the drivers from there. You should also make sure your laptop is compatible with Windows 7 by checking out Windows 7 Upgrade Advisor.
Good Luck,
NOLA Tech
Jan 31, 2010 | Toshiba P25-S526 Notebook
Screen is blank when starting computer
Need a longer explanation of your problem. What os is in computer. Is ac plugged in. Can you get into the bios? (Usually pressing F12 or something on bootup.)
Nov 07, 2009 | Toshiba P25-S526 Notebook
USB devices not detected
go to the bios and check the boot device order, if the option for usb boot is there makes it first, ortherwise make cd/dvd as your first boot device, ........... enable all the usb options available on your bios
Oct 10, 2008 | Toshiba P25-S526 Notebook
My laptop is a toshiba satellite P25-S526. I cant seem to get the power supply to charge the battery. I have replaced both the battery and power supply and those were not the problem. why wont my...
If you have a volt meter measure the power coming out of the power supply and make sure the outlet is good that you are plugging it into.
Try resoldering the connection on the circuit board where the power supply plugs into it. There may be a loose connection or a crack in the board that you could jumper around using a short piece of wire soldered around the break.
Aug 26, 2008 | Toshiba Computers & Internet
Shutting down
Does it cut out on battery?
How often does it cut off?
Does it just die (no lights or anything) or reboot?
Jan 14, 2008 | Toshiba (K000006610) for Satellite P25...
Will not power on
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the ... This will help verify that the strip or switch is not bad.
Click on the above link and follow instructions.Thank You, Please dont for get to Vote.
Dec 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Computers & Internet Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
