Question about Toshiba 53H71 53 in. Rear Projection Television
Multiple images on right side of screen
I have multiple images on the right side of the screen, mostly in red. I tried the auto convergence and it gave me the message that there is an error. I tried the auto convergence again as recommended in the manual, same message. I then tried to use the manual convergence and can only get position 1 and 4 to match up. Position 2 and 7 are close. Position 3, 6, 9 are so far off that the cross is bowed for the vertical line. Is this something that can be repaired by me?
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergance amp ic bad
Posted on Jan 22, 2008
Concave image and multiple images on the edges along with multiple colors of green, red, and blue.
It is a convergence problem.
Tell me brand and model number and I will tell you what is needed or if it is reasonable to repair.
SD TECH
May 22, 2010 | Sony Televison & Video
Display's Multiple shadows/images on screen
Ur convergence is dead.Must replaced 2 convergence ICS,and some or all it resistors.Must know how to solders?Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will $300 for parts and labors.
Mar 09, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
50 inch hitachi tv, shadow behind writing and crooked screen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Red convergence out
Jul 05, 2009 | Samsung HCL5515W 55" Rear Projection...
Rcs hdtv multiple images
The problem you're having is due to the failure of the convergence amplifier circuit. In that circuit are some components which amplify or control the signals to the dynamic convergence yokes, which line up the red green and blue images to superimpose them over each other to create a proper colour picture. When you get a failure in that circuit, it no longer aligns the images properly, and generally you get what appears to be badly set geometry in multiple colours. In some cases you will also get a problem with the part of the power supply that supplies the convergence amplifiers, or the digicon, which is the digital convergence control module.
Jun 12, 2009 | Hitachi 43FDX01B TV
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
KP-51WS510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 01, 2009 | Sony KP-51WS510 51" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence Problem
I'm not a 100% positive this would fix your TV, but I found the convergence board on PartStore.com for about $80. Hope this helps.
Nov 16, 2007 | Akai PT5598HD 55" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
