Question about Marantz SR5001
Cuts out after playing for a variable period - Marantz SR5001
  • 4,234 Answers
There is an internal problem that is causing the unit tio either heat up (thermal protection circuit kicking in) or a part is failing under load and the standard protection circuit is kicking in. In any case, this unit needs service to track down the problem. Since it works most of the time, it could be as simple as a poor solder connection that the heat of running effects. This could well be a repair that does not require parts at all.
Dan
Posted on Oct 07, 2009
Checked impedence of speakers Too high
How much is intereston 1 varable 2 fixed rate
interest is interest
fixed is calculated yearly on the principle and is paid 365 days time
variable changes and is calculated daily ( 1/365 part of the interest rate ) and added to the remaining principle monthly
so if you have a loan of $1000.00 on fixed interest of 10% , regardless of how much you have repaid in a 12 month period , it is 10% of the principle loaned
with a variable interest the interest rate could be 10% today, 15% in 2 months time or 6% later on
it is variable
to add to that it is calculated on a daily basis (1/365 of 10%) and added to the principle left after receiving a payment on the loan
so for a $1000.00 the interest is added to that principle at the end of the month if there is no loan repayment or is added to the principle balance after a payment
the difference is that a variable interest rate loan will allow you to save money if you pay off well before the period of the loan but will add almost 2 to 3 times the loan if you pay the absolute minimum for the period of the loan
a fixed rate is where you know exactly the total interest to be paid at the end of term
May 09, 2016 | Computers & Internet
Tip
The difference between fixed and variable annuities
Annuities are available in two forms called fixed and variable annuities. The main difference between the two plans is how earnings are generated and how much risk is involeved in the investment.
Fixed annuities are plans that you can get from an insurance company that have a fixed interest rate for a set period of time. When this period is over the insurance company renews the interest rate an other set of time. Some fixed annuities have a guaranteed minimum interest rate for the life of the annuity. The fixed annuity plans feel safer to some because you know how much interest you are going to be recieveing on your investment.
The other kind of annuity is a variable annuity. In the variable annuity plan you invest your money into a few investment options. The return of these investment depends on how the investments do. Variable annuities have a higher risk than those of variable annuities but can also result in higher returns if the investments do well.
It is recommended that you do your research before making an investment in any plan and talk with a financial advisor that you trust.
on Sep 11, 2013 | Finance
Red giants
Mira-
Mira was named by Polish astronomer Johannes Hevelius. The name means "wonderful" or "astonishing" in Latin. The star is a model for the category of stars known as Mira variables. Mira variables are pulsating variable stars, usually red giants, with pulsation periods longer than 100 days and light amplitudes exceeding one magnitude.
Sep 04, 2014 | Optics
2003 Mazda6, after the engine has warmed up, when I'm in gear and at an idle it will periodically drop between 25-50rpms and then return to its normal idle. Why?
Engines rarely idle at the same rpm all the time. Its normal for changes to occur, especially small ones. Too many variables that can effect such a small change to list. Its no an issue to worry about.
Aug 15, 2014 | 2003 Mazda Mazda6
Formatting problems
older mp3 players cannot handle bitrates higher than 128 and you should not be recording them with variable rate either. I recomend, deleteting the card and start new with a standard bit rate
Feb 14, 2014 | Audio Players & Recorders
Band saw cutting problems
Make sure that the blade is properly tracked and tensioned, installed. Hope this blog will help you too. http://bandsawblog.com/variable-pitch-band-saw-blades-when-is-it-used/ . Variable pitch blade is a tooth design that combines more than one tooth pitch to reduce chatter and vibration .
Feb 15, 2013 | Saws
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
Amp cuts off after prolonged playing
Overheating...it sucks...the same happens to mine. I use a fan just behind and it jeeps working.
May 12, 2009 | Audio Players & Recorders
Marantz SR5001 Logo
91 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
