Question about Acer Aspire 4520-5582 Notebook
My screen goes black and you can still see every thing in the background i shut the lid and reopen it and it will come back on
  • janobl Oct 07, 2009
    its is not my brightness level it is almost like a lose wire
    like i said, it goes black i close the screen and re-open it and then it will work again for little while until it gets moved
    Problem Solver:
  • 12 Answers
Turn up the brightness level. there should be a key labeled "FN" or "function" or something along those lines somewhere on your keyboard. a couple of the "F" series keys (F1 through F12) probably have a diagram on them that looks like a square with a sun in it. one of these two keys will make it brighter, while the other will dim it.
Posted on Oct 06, 2009
Screen goes black after a couple hours
There are a couple of possible causes and solutions... Please give some more info.
Is the hibernation period long enough to allow the TC4200 to cool down or is it just long enough to close the lid and reopen it?
I believe I can give you a definitive answer with more info.
Jan 26, 2014 | Compaq tc4200 Tablet PC
Screen goes black , but when you close the lid and reopen it comes on just a bit then goes black , Is the screen bad ??
it could be the switch that change to Standby mode when you close the lid <br /> I can fix this <br /> <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a><br />
Aug 26, 2010 | Toshiba Satellite A135-S4527 Notebook
Dell inspiron 1525 laptop screen goes dark @3minutes after turning on and then when I shut the lid and reopen lid the screen turns back on for 15sec then turns back off...repeat steps and you see my...
Sounds like a loose connection or bad capacitor. If it's a loose connection then after the initial three minutes of warming up the connection separates that's why you only get a picture for 15 seconds after rebooting. If it's a bad capacitor the same is true but for a different reason. The bad capacitor will work until it gets too hot then you're out of luck again. It could be the LCD or the video card.
Feb 13, 2010 | Dell Inspiron 1525 Laptop
Dell D610 Screen Black, But Power Still On
Hi my name is Eric,
I hope I can help you with your isue,
 Thats the way these dells are, the standby mode sometimes puts it in hibernation.
Check the settings in the screen saver/ power area
If I have helped you pleae click accept
we can till post until the post expires
Thanks
Eric
Sep 27, 2009 | Dell Latitude C610 Notebook
HP pavilion dv2000 screen black
Maybe there are to many programs running in the background and thats interefering with the sleep function of the laptop cause it can't allocate enough memory to allow the screen to come back on.
in the search box in your start menu, type in msconfig and press enter. This will take you into the system configuration utility click on the startup tab and this will show you all the programs that are started up when you boot up into windows.
Go ahead an click on the button that says disable all, this will uncheck all of the boxes. Click on apply and then click on Ok and let the computer restart.
Once it restarts and you get back into windows, try again and you should be able to close the lid and then bring it back up and have the screen come back on like normal.
May 12, 2009 | HP Pavilion dv1000 Notebook
Dell Inspiron B130 won't wake up after closing lid
Right Click on desktop--> Properties--> ScreenSaver-->Power--> Advanced
And from there U can set the things According to u
Hope It Solved Your Problem
Good Day
Apr 13, 2009 | Computers & Internet
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Black screen
It sounds like your “Suspend Switch” is acting up. The Inspiron 1501 uses a mechanical switch to detect if the lid of the system is open or closed. A camber is built into the hinge of the system that activates the suspend switch plunger as the LCD is lowered to the closed position. If the switch is broken or nonfunctional, then it can be replaced separately. It is located under the hinge cover next to the right hinge on the system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 28, 2008 | Dell InspironTM 1501 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Acer Aspire 4520-5582 Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
