I have a Mitsubishi VS-466R Projection TV that wont turn on, I hit the power button on the front panel of the TV and it seems likes its turning on but then you hear a buzzing noise coming from the back and there is no picture or sound or anything, Just a blank screen. Ive looked at all the wiring i could could not find anything wrong. I do not have a manual and could not find one online. I was wondering if there is any trouble shooting or things i should specifically look for. Thank You.
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
techman
  • 3130 Answers
SOURCE: Mitsubishi Model No VS-5069
You will need to contact a glass place to cut a new mirror that has the reflection paint on the outside of the glass instead of what most mirrors have them painted on the opposite side . Good luck
Posted on Jan 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Posted on Aug 19, 2008
  • 1153 Answers
SOURCE: troubleshooting hv shutdown on mitsubishi vs-4543
Did you replace fuses going to low voltage supply going to amps?
Posted on Oct 16, 2008
Laurens mom
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Posted on Feb 22, 2009
Mitsubishi big screen model vs-50604. i hit a button on the front of the tv and now all i have on the screen is a caption that says installng guide plus data now. is there a reset on the tv anywhere. i...
Open the front panel. Just to the left of the RCA imputs is a small button that says reset. You may need to use a pen or paper clip to press it. Press that and the system will reset .That should fix your issue, or do like me and get a Sharp. LOL. My bulb went out 2 times and I got irritated with it.
Nov 07, 2013 | Mitsubishi VS-50605 50" Rear Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Could the front contol panel be bad if my T.V. dont turn on
More likely no power to set; either no AC from plug outlet, or internal fuse in power supply.
Apr 19, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-60705, Turns on/Turns off.
Unfortunately you will need an experienced TV tech.
This unit will need 2 ICs STK392-110 for 1 has shorted and caused damage to the 2nd as a result blowing 1 or 2 pico fuses in the power supply.
It is an involved job and may be somewhat costly depending on the pricing in your area.
Hope this helps Normal 0 false false false MicrosoftInternetExplorer4
Jul 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
VS 5001R sounds like its gonna turn on but doesnt
This chassis model line had issues with the vertical output IC shorting causing shut down.
It also had issues with intermittent solder connections in the Horizontal Circuit. I would not try to fix it your self unless you are very familiar with Projection circuitry and electronics background.
Hope this helps,
Skyassoc
Jul 02, 2009 | Televison & Video
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi tv
Could be a power supply problem - sounds like the feeder cap was failing slowly until the heat stress on the regulator finally gave out.. You'll want to check the following: Strm6515A (That's the regulator, R9a23 1.2 ohm, C9a15 220uf/35v , R9a0 1k all in that feed circuit for the regulator.
Bill
Jan 29, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
