Question about Hitachi 53UDX10B 53" Rear Projection Television
Bowed picture My picture bow's down from the top and bow's up from the bottom. The picture bounces back and forth from a good picture to a bowed picture
  • aust82 Dec 28, 2007
    i can't adjust the blue in the convergence menu. the picture bounces back and fourth between all colors aligned and blue bowing
  • kaymanc Jan 03, 2008
    my tv has a problem with the green it is not in lined is the tv worth fixing or just junking
    Sergeant:
    Champion:
  • 346 Answers
Malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Posted on Dec 23, 2007
Screen is bowed on top and bottom. What could be our problem? Picture, letters & words blurry.
go to hatch screen adjust all colrs to make white color boxes , also adjusts linear lines
Dec 31, 2009 | RCA Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Cheap Fix?
I will strongly advise you to replace the two STK392-120 as a pair. and this will cure your bowing picture problem. You may need to re-converge your set. best of luck.
Nov 05, 2008 | JVC AV-48WP30 48" Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Me again
With the bow in it it's likely the convergence has failed... Where did you purchase the amps that you put in it? Did you use a good heat sink grease to mount them?? Did you really scrutinize the resistors in the feed and return circuits???
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
53swx10b bowed picture
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Mar 12, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Bowed picture
you have pincushion problems and may convergence may require a setup/call for service.
Aug 12, 2007 | Philips 43PP9202 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
452 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
