Question about Vizio P2 42 in. HD-Ready Plasma Television
TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
I have the same problem but my TV is 3 month old
  • Vizio Master
  • 8,457 Answers
Return for Warenty repair,video board main backlight prob. the board is dead.
Posted on Oct 12, 2009
  • 4 Answers
SOURCE: My vizio tv flashes like a strobe light
Sounds like your Backlight Inverter Board is going out, saw one on ebay for about $55 : ) have to get the one for your model tho...
Posted on Aug 21, 2009
SOURCE: Vizio TV will not turn on.
I had the same problem. The orange/green light in the front was off as well. I unplugged it, held don the power button for one minute then plugged it back in. It's working now, but who knows how long it will last. I found that solution elsewhere on the site. Thanks for the tip whoever you are!
Posted on May 06, 2009
dsacco86
  • 1077 Answers
SOURCE: TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
http://www.vizio.com/support.aspx?id=1588
Posted on Jun 28, 2009
dsacco86
  • 1077 Answers
SOURCE: power
The reason the tv is turning itself off, because most TVs have a "Protection Mode" that turns the unit off when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
Being that the TV is under a year old, it should be still under manufacture warranty. Last thing you want do is void the warranty by opening up the TV. Here's some info to get you started on the warranty:
If it not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
  • 27 Answers
SOURCE: Vizio VX42L LCD TV died?
it is the power supply. in the given scenario like yours, the PSU is the suspect in 90% of the cases.
Posted on Apr 09, 2010
Testimonial: "alteans is very helpful."
The cause of a black horizonal line across screen
One among its back light CCFL tube might have damaged. Replace the set as warranty is active.
Jun 13, 2012 | Vizio GV42L 42 in. LCD Television
Hey there, I have a 6 month old vizio 32" LCD 60hz
LCD inverter module may have encountered a failure. Most common is an electrolytic capacitor failing in the power supply. Examine the board to see if any of the caps have a bloated or raised top, they should not be swollen or leaky. If so find the replacement capacitor # on line and replace. You will require a modicum of soldering skills. You indicate the tv is 6 months old.
Return it for warranty service, do not open your tv or you will void your consumer warranty.
Mar 26, 2011 | Vizio L32 32 in. LCD HDTV
Vizio VO420E 42 in. LCD TV -- Less than 3 months old. Picture slowly darkens and then goes out all the way. Sound stays on. Picture goes out. We turn the TV & cable box off, wait 30 seconds, turn...
the problem its the main board of the tv not the power supply board.the main one controls all your imputs tv av component etc the cheapest place to find it its at www.shopjimmy.com cheaper than the manufacturer and those dudes that you find online that charge an arm and a leg just to come and just repair your old main board mine as well buy a new one at this site for less ok and you are welcome
Apr 13, 2010 | Vizio VO420E 42 in. LCD TV
Jun 27, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
HELP PLEASE Vizio Plasma tv broken again - possible driver board?
This could cause by the power supply or the mainboard.
- If the LED stay Green when you turn on the TV. But you can not turn it off, in this case the main board has failed. Replace the mainboard will fix the problem.
- If the LED light always stay at Orange, you can not turn on of off. In this case the mainboard also has failed.
- If you turn on the TV you will hear the power supply click on the LED is green then it click off the light turn Orange. In this case the power supply has failed.
Which boards did the repair shop replace?
Hope this will help.
Feb 18, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio gallevia no picture
I EMAILED VIZIO ABOUT MY PROBLEM. THEY RESPONDED IN 3 DAYS. THE TECH AND I THEN TRADED A COUPLE OF EMAILS. HE CONFIRMED THE INFO ABOUT THE TV WITH ME. HE EMAILED ME THE SOLUTION TO THE PROBLEM AND PART NUMBER. IT WAS THE MAIN BOARD. I ORDERED THE PART AT VIZPARTS.COM FOR ABOUT 180.00. INSTALLED IT MYSELF AND THE TV WORKS FINE. I WISH IT HAD BEEN UNDER WARRANTY BUT IT WAS 18 MONTHS OLD AND THE WARRANTY WAS FOR 12 MONTHS.
Jan 03, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Nov 24, 2006 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
353 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
