Question about Microwave Ovens
No power ,completely dead - Microwave Ovens
    Novelist:
  • 121 Answers
The fuse may be bad.if u r somewhat handy. you can try and fix yourself . fuse can usually be purchased at a home improvement store. 20 or 15 amp fuse. un plug unit remove top grill usuallly two phillips scews in the grill or 2-3 screws on the top of the microwave frt. next remove front control panel usuallt 1 screw at top of panel . once the control panel has been removed you can look inside that area and see a fuse, its ceramic usually white or grey and sits in a fuse holder. you can test it if u have a meter. should read resistance if good if no reading it is bad. replace it with same volt youtook out. if you rather a servicer doing it, then could cost anywhere from 65.00 to 105.00 to fix in home. if u take it in to get repaired then 85.00-125.00 depending on were u live and who u use. do it yourself for around 2.00-5.00 for fuse.always check power to unit first before you repair . use a extension cord to same outlet and see if that appliance works.hope this helps you.
Posted on Oct 06, 2009
No power, no clock, no light. Dead
you cant do much about this.. the only thing you can do is check if the power is going to the magnetron unit or not.
but i wouldnt suggest you to experiment with the unit as it can cause short circuits.
you should rather go find a cheap electrician
Mar 17, 2014 | Microwave Ovens
Unit is completely dead
please check the fuse - you will be able to locate it on panel. - replace it and the pcs is ok --
Feb 23, 2014 | Samsung SMH9187 Microwave Oven
Dead
if its dead its more than likley the fuse you have to take the cover off make sure its unplugged you will see the fuse replace it with the same kind and then try it
Mar 05, 2013 | Microwave Ovens
My Model is Samsung timesaver 1000 W, M1934NCE. Made in malaysia, September 2002. No power at all. Completly dead. Please help me to fix this.
possible solution
checkpower unit like fuse
check transformer which gives different supply to various part of oven
May 15, 2012 | Samsung Microwave Ovens
No power to oven; checked power to outlet and I do have power; looked for reset button but did not find one
If it is completely dead, check the main fuse, which is likely a AGC ceramic type. If dead, you can buy from Electronix: http://www.electronix.com/ and click microwave in the left column. Good luck with it.
Apr 19, 2011 | Magic Chef MCD1311ST Microwave Oven
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Complete Shut-Down
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 23, 2007 | GE Monogram ZE2160SF Convection /...
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
