Question about PfaFF Hobby 4260
Hobbylock 788 has broken. Shaft that holds needle box is going too high - has snapped upper casing clip
4 Suggested Answers
  • 78 Answers
SOURCE: How do I adjust the needle shaft position on my
take the end cap off and follow the needle bar up until you see a block with a screw in the middle of it.bring the needle bar down useing the handwheel to its lowest position loosen the screw and you should be able to move the needle bar if you have a needle threader you can use it to reset the height of the needle bar just bring the threader down and then lower the needle bar to where the threader fits into the eye of the needle like it would if it were being threaded
Posted on Jul 01, 2010
SOURCE: The shaft piece on my hobbylock 786 serger is loose
The top hex screw I think holds the bushing that allows it to slide freely. Keep that loose. If you open the panel where the lightbulb lives and spin the wheel, you will see a small flathead screw come into sight near the top of the rotation, through a small round window in the case. Tightening this screw a bit should keep the needleshaft moving with the wheel. Unfortunately I am still trying to find out how to position it so that it's properly timed.
Posted on Jan 06, 2011
  • 45 Answers
SOURCE: Hi :) Just got a Hobbylock 788 and need to thread
Here is the trick: If you look at your thread spools, left to right, thread machine beginning with thread from spool 3, then 4, then 1, then 2.
Thread 4 is tricky. You must line up the purple line on the big wheel on the right end in order to do this. Thread the machine according to the diagram on the inside, then, making sure you lined up the purple line, push the lever at the bottom of the machine (below threading guides) to the left while holding on to the thread end. This will push the thread up and along the horizontal arm you just threaded.
Posted on Feb 16, 2011
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Jun 14, 2017 | PfaFF Sewing Machines
Singer sewing machine Model 9134, problem trying to put the bobin case back in after cleaning, how do I put it back together?
make sure the needle is in the upper most position and the clip on the bobbin case is facing you
It should just clip in on the shaft
May 01, 2015 | Singer Sewing Machines
How do i tighten the needle holder on a pfaff 788 hobbylock serger
I have the same problem, thee needle holder shaft swirls from left to right, is very loose. Maybe there is a screw missing, but which one? Please look at the pictures.
Feb 28, 2013 | Sewing Machines
Top thread breaking?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 22, 2012 | Sewing Machines
How do I adjust the needle shaft position on my Hobbylock 788. It somehow shifted up.
Jun 30, 2010 | PfaFF Hobby 4260
Mar 21, 2010 | PfaFF Sewing Machines
Needs new needle bar, needles do not remain parallel with each othe. none in stock locally. Pfaff hobbylock 787, 788
Check out http://www.pfaffmachines.co.uk/partsDB/index.php?category=Needle_Bar_Parts
It looks like this site has everything you'd need for a Pfaff machine!
Jan 24, 2010 | Sewing Machines
Jan 20, 2010 | PfaFF Sewing Machines
I have a hobbylock 776. The square box on the shaft that holds the needles is broken. I think the holes for the screws are stripped. I believe it is the needle bar. Can not find a part.
You will need a new needle bar. Call your local Pfaff Dealer, as this part is only available from them (if at all). The needle set screw holes could possibly be tapped and fitted with different screws as a last resort, but I wouldn't count on it.
Jan 02, 2010 | Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
