dryer does not shut off when on the settings other than the timer. easy care and cotton settings have the more more dry, optimum dry, etc, when set on these the dryerstays running until you shut it off.
I have a dwsr405eb0ww dryer and it seems that the heat is intermittent. I dried a load of cloths but...
(More)
I have a dwsr405eb0ww dryer and it seems that the heat is intermittent. I dried a load of cloths but the next load didn't have heat. I tried it again this morrning with a pair if jeans but 10 min later no heat
how do i open the front of the dryer to replace the gasket seal to stop the brown marks on my...
(More)
how do i open the front of the dryer to replace the gasket seal to stop the brown marks on my clothes and stop them from getting stuck in between the gap.
GE Dryer Model #DWSR483EB2WW Dryer tumbles, but there is no heat. Fuses are ok and air flow appears...
(More)
GE Dryer Model #DWSR483EB2WW Dryer tumbles, but there is no heat. Fuses are ok and air flow appears to be good. Do I need a new heating element?
Dryer turns on and dries fine, but makes a buzzing noise at knob. My elderly mother thinks it was...
(More)
Dryer turns on and dries fine, but makes a buzzing noise at knob. My elderly mother thinks it was hotter than normal when she put one pair of dry pants in the dryer to dewrinkle them today. I just used it recently for about 3 loads of wet clothes that dried fine. I think the dryer appeared hotter because she had one dry pair of pants in the dryer. Dryer has made slight buzzing noise on occasion for several months now. What do you think?
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my...
(More)
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my GE DBSR453EB2WW dryer is broken. How do I begin to disassemble the sides/top to get at this? Where do I start?
