Question about HP LaserJet 3055 All-In-One Printer
Printer is connected and on. Shows as offline.
Setup as a Workgroup printer. Printer is connected and on. However it shows as offline. In the right click menu for this printer the 'connect' button is grayed out
  • 657 Answers
Go to Control Panel
Open Printers and faxes
Right click on your printer icon
Uncheck Use Printer Offline
Check if the printer is working ( A restart may be needed)
Posted on Oct 06, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Brother HL-2270DW printer shows offline and won't print
I had this problem today with my wireless Brother MFC-990CW using Windows 7, and when I went to see what s printing, then printer, it wasn t showing that I had checked the use printer off-line
So, on my pc I went to the start button then chose:
- Computer
- Network
- Double click your printer
- New print drivers will start to install
- Right click the icon that is a copy made of your printer setup
- Set this as your default printer
I was then able to print and my printer didn t show as being off-line anymore. This is a lot easier than having to uninstall and install the printer again using the disc.
Source(s):
https://answers.yahoo.com/question/index?qid=20140422184955AA0dJ7F
Jun 27, 2012 | Brother HL-2040 Laser Printer
Printer shows offline still it is connected to pc and powered on....
just right click on printer and click on offline
if problem persist then trying with reinstalling
Aug 03, 2011 | HP DeskJet F380 All-In-One Printer
Printer says it is offline but is pluged in
Hi there!
If the printer shows offline even if the USB cable is connected, I suggest to uninstall the driver and reinstall it. If it still shows offline after reinstalling the driver, it is possible that there is a problem with the printer itself.
Hope this helps.
Jun 13, 2011 | HP Office Equipment & Supplies
Our HP 3100 All in One printer is "offline" when we check in the Control Panel under "printers". How do we get it back online?
Under printers, On the Hp 3100 model, right click on it, if it shows Use Printer Online then select that Option. Else if it shows "Use Printer Offline" it means to say that your printer is online.
Also check that whether the Power is On to the printer. Communication cable is connected. Proper printer port is selected.
Sep 05, 2010 | HP Office Equipment & Supplies
LaserJet 1022 Printer: After installation Hp laser 1022 printer itts show...
Make sure the cable from your printer is properly connected to the CPU
Make sure it is well recognized.
On start menu, click printer and faxes..
you will see your printer model.(if you said its offline then the image of your printer is blurred...right?)
Now right click on the printer model.. and click the "Use Printer Online"
After that you will see that the image of your printer is clear with the word "ready"
Try to print again.
May 16, 2010 | HP LaserJet 1022 Printer
The HP printer is connected but the icon shows "offline"
Go to control panel, then select printers. Then, from the list of printers (if you have more than one), right click on your printer and make sure "Use printer Online" is checked.
Hope this helps.
Jan 12, 2010 | HP Photosmart Premium C309A All-In-One...
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Offline
go to printers folder, right click on printer icon and select connect, unless the printer is dissconnected
Aug 29, 2008 | Epson ACULASER CX11NF All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
4,302 people viewed this question
Seeker5211
Seeker5211
