Question about Dryers
Wanted to get pictures or diagram on kenmore model # 87994800 gas dryer because dryer runs but no heat. I read troubleshooting and know what parts I'm suppose to look for but don't know what I'm looking at. What can I do to see a diagram on my computer.
    President:
  • 1,304 Answers
Gotyo www3.sears.com
you can type in your model
and it will give you a pictoral breakdown
and al parts are labeled
Posted on Oct 06, 2009
Testimonial: "Thanks, it was helpful."
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
We cannot find where the ignitor is on our model 747122.
It is down on the bottom of the dryer attached to the burner.... I am sending you a link that shows all of the parts to a 74712 dryer. Go to the burner assembly and it is # 4
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11074712200/0582/0151200?searchedModel=74712&blt=11 arrow down to the burner assembly diagram and double click the picture to blow it up and it will give you the parts break down. Hope this is what you wanted....
Feb 13, 2011 | Kenmore 74712 Gas Dryer
My Kenmore gas dryer 76812691 will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace. Here is a video at this will walk you thru the troubleshooting a gas dryer. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Sep 29, 2010 | Dryers
Runs but no heat has good gas flow to dryer will not heat and makes a humming sound during what should be the heating cycle
Sep 20, 2010 | Estate TGDX640JQ Gas Dryer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
I have a gas Kenmore dryer 80 series mod # 110.76862500. The dryer runs ducts are clean and it blows air but it doesn't heat up.
check the spark control ignitor and the moister sensor as well. if a click is not heard upon turning it on with the setting switched to high heat the ignitor is at fault
Jun 16, 2010 | Dryers
Gas kenmore dryer, no heat . the gas heat does not turn on. i tried running it without the vent but no help.
It could be several things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 25, 2010 | Kenmore Dryers
Dryer not heating
The following link explains how to diagnose and troubleshoot a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Please read through the link I provided you thoroughly. There are several components that can cause a no heat problem. First and foremost, make sure you have the proper voltage at the electrical outlet. You should be reading 220-240VAC at the receptacle. If part of this voltage is missing, the dryer will still run, but will not heat. That is because the heating circuits require 220VAC to operate, but the drive motor only uses 110-120VAC. Let me know if you require further assistance. I hope this helps.
PS If you ask for further assistance, please provide your MODEL number (located on a nameplate around the door opening) as all dryers are not contructed the same. This can make a difference in where the components are located, and how to take the the dryer apart.
Nov 12, 2008 | Kenmore Dryers
No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Oct 17, 2008 | Dryers
No Heat
have same problem with my dryer. Check your sensor out,
Jun 14, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
111 people viewed this question
Top Dryers Experts
