Question about Day-Timer Intermatic T2005 Timer SPDT 20A 125V TIME SW
Need a picture of an already wired T2005
Need a picture/diagram of an already wired T2005 intermatic timer
  • 8,404 Answers
You are placing a pretty tall order here. You want someone to go to a timer that is wired - take a picture of it, transfer it somehow to the computer then attach it here somehow and or draw a diagram ... and for what benefit???? There is a schematic on the door of the switch, at least the dozen or so that I maintain anyway.
There are three termnals in the switch, a common for a white, a hot black and a switched black.
The "line" is the hot black and a white. Your load (white can come to the line white if you want but it is not necessary) a black wire that goes to your light or motor or what ever you are turning on.
If this is a two pole switch (220 V AC) please indicate in your question/response.
If I have misunderstood your question, pleae ask again.
thank you
a
Posted on Oct 06, 2009
I need installation or wiring diagram for Timer Intermatic T101
Copy following link for 120Volt T101 timer wiring options:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 29, 2011 | Home
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
How to wire model t10004 control panel intermatic inc? I am just looking for a picture of the wiring diagram. All I need to do is hook up a the wiring for the light.
T10004 control panel has 240V T104 timing mechanism.
1) You can use T104 timer to control 120volt light if you have a neutral wire:
http://waterheatertimer.org/images/T-104-control-120V-Load3-45.jpg
2) Lights are usually 120Volts with black hot wire and white neutral wire.
3) T104 timer is 240Volts with two hot wires L1 and L2 that can be white-black wires or red-black wires.
4) Open following link to see basic 120V and 240V circuits.
http://waterheatertimer.org/B220C.html
5) Open following link for T104 wiring options
Jul 17, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Can you fit a frost switch to the T10404R
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/PF1102.ashx
http://www.poolandspacontrols.com/products/freeze%20protection%20controls/multi%20circuit%20freeze%20protection%20controls.aspx
Intermatic makes a freeze protection control that wires directly into a 240V timer.
If you already have a freeze control, the wiring diagram might help.
The manual has this image larger.
It shows wiring to connect the freeze control directly to one 240V timer.
Intermatic make a freeze control for 1 or 2 circuits.
Intermatic page showing Pool and Spa timers
http://www.poolandspacontrols.com/products/mechanical%20controls/100%20amp%20specialty%20control%20panels.aspx
Nov 11, 2010 | Intermatic T10404R - Two 220 time clocks...
Looking for wiring sequency
1) Intermatic has manuals for each product. Manuals have wiring diagram, but you have to identify product number. Look for product number and wiring diagram inside timer door.
2) If you know product number, and are still confused by wiring, then repost question providing as much information as possible. You also need to post what voltage wire you are putting timer on.
3) Here is link to manual page:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
4) Here is link to product page: for example sprinkler timer: Click on product number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Sep 18, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
How to wire this T2005 SPDT to 2 circuits
Here is the link to Intermatic... you can find the wiring diagrams for any timer there...
heatman101
Sep 18, 2010 | Day-Timer Intermatic T2005 Timer SPDT 20A...
T101
Here's the wiring diagram:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
The wiring is as follows:
Connect _both_ the incoming and outgoing neutrals (white) wires to the "A" terminal. The incoming [(LINE) (hot) (from the breaker or source)] black wire is connected to the #1 terminal and the outgoing (LOAD) black wire is connected to the #2 terminal.
Both of the bare or green wires are twisted together along with a 6 inch or so pigtail using a red or yellow wire nut. The pigtail is then connected to the green "GR" screw on the enclosure.
May 07, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Day-Timer Intermatic T2005 Timer SPDT 20A 125V TIME SW Logo
139 people viewed this question
Top Day-Timer Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Day-Timer Hardware and Accessory Expert? Answer questions, earn points and help others
