Question about Kenmore Blender Single-Speed Blender
My kenmore blender stopped blending!!!
My blender stop working the blades dont cut anymore they are loose and the bottom screw gave up that supports the blades.
  • 87 Answers
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Posted on Oct 06, 2009
Testimonial: "Thanks i just cant find where the sell the parts at but you really helped me!!!"
  • gail long Feb 06, 2012
    Who did you order it from? I need he same part.
  • 81 Answers
Kenmore is a very nice brand in blenders and generally it works very nice as well. But if problem persists, then you need to repair it. I suggest go to its dealer and tell them the problem. And for any further details or any additional queries, please click here:
GroomNStyle Best Kitchen Blender Reviews 2015
Posted on Jul 23, 2015
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Jul 10, 2008 | Blenders
I have the tsk-9368ap blender model. Before I blend, I lock the blade in place on the bottom, while I am blending the blade comes loose, and whatever I am blending starts coming out of the bottom, I'm not...
kalexis - there is no such thing as support for the Durabrand TSK-9368AP - Wal-Mart decided that the products were so cheap that people would buy a new one if it broke. What I would do is take your blender into an Ace or True Value Hardware store, and have someone find a generic gasket that will fit your blender.
sheens1953 - the seal/gasket for the Smoothie Maker Elite can be found here:
http://www.focuselectrics.com/finditem.cfm?itemid=4308
-Tha Mp3 Doctor
Jul 10, 2008 | Back to Basics Smoothie Elite Work Top...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Kenmore Blender Single-Speed Blender Logo
981 people viewed this question
Top Kenmore Blenders Experts
Gil Shultz
David Ellis Rhea
Sonal Khare
Sonal Khare
Are you a Kenmore Blender Expert? Answer questions, earn points and help others
