Question about Tomtom GO 910
Need L2 inductor spec on TomTom GO 910
I need the electrical specification and ideally the manufacturer of the LED driver inductor L2 on the TomTom GO910 main PCB. It broke when I removed the GPS module.
Had exactly the same scenario. Must be a production flaw that L2 sticks to the GPS piggypacked board.
Looked into another TT and found a 100 (µH assumed) on the same spot for this backlight P/S. Took an old Vodaphone/Arcor DSL Modem apart and found three coils 101, 2R2 and 100 ......
The 100 is working fine - had to shift it aside by some jumper wires.
Light is on again.
Detlef Harpers
Dipl.-Ing. Germany
Posted on Nov 15, 2009
  • wayne walker Dec 12, 2011
    any idea what the part number for U13 is on the same circuit. I have just bought a go 910 from ebay and the seller was not fully truthful( surprise surprise) about someone else having a go with a soldering Iron. I found solder balls and the chip is getting warm when unit powered up
Power spec 6342
WinBook PowerSpec 6342 Specifications The specs for PowerSpec 6342 comes in these configurations with a retail price tag. The configuration WinBook provides comes with a 3.06GHz Intel Celeron D 346 n/a Serial ATA, Ultra ATA/133 PCI/AGP 160.0 GB Windows XP Home SP2, S3 Graphics Unichrome PRO 128 MB DDR 128 MB DDR (shared).
This WinBook Computer can take up to 2.0 GB ram, with a fixed amount of 512 MB (removable) installed PC3200 DDR SDRAM DIMMs.
This full-featured mainstream Computer enhances the previous generation WinBook models with the chipsets and new levels of customization. Get the best experience on your WinBook PowerSpec 6342 Computer with improved performance, make it easy to create a home network and share all of your favorite items.
The specs of Computer shows full configuration information. The PowerSpec 6342 is designed for users who require maximum performance in a mainstream Computer. Even with its form factor design, the PowerSpec 6342 doesn't skimp on performance offering the ideal blend of power and efficiency.The PowerSpec 6342 is sure to leave a lasting impression with its easy to use and slim design. Located on the side of the unit, the modular bay's innovative latch is designed for easy insertion and removal of the various module options.
The PowerSpec 6342 Computer only supports 3.06GHz Intel Celeron D 346. The PowerSpec 6342 features two on-board data caches for transferring information to and from the processor. These caches are known as the L1 and L2 caches. The PowerSpec 6342 L1 cache is 64 kilobytes in size, while its L2 cache is rated at either one or two megabytes.
When you have a clear idea of which Computer best suits your needs, check for its specifications. As the PowerSpec 6342 is supported by WinBook, check if the Computer has full support and warranties by its manufacturer, like PowerSpec 6342 specs you will have lots of options from the Computer manufacturer to choose from, like the Computer processor, Computer RAM, its graphics capacity, Computer display options and specs, and other features that the Computer provides. You should have an idea on what specs you want from your Computer and what specs you do not want on your Computer, deciding on Computer specs may be difficult task to do but like the PowerSpec 6342 specs have, it's essential to selecting a Computer you need at a price tag that it deserves and that you can afford.
Here is a sample PowerSpec 6342 Computer specification if you want an initial guide to buy a Computer. More or else, these are the specs factors often that you should take into consideration before you purchase a particular type of Computer. To help you navigate around the hassles of buying a Computer, we have the standard specifications for most home and small business users.
Jun 11, 2014 | Computers & Internet
Tip
DS Lite not turning on? Read this tip to find out how to fix it!
Have you dropped your DS Lite and now it rattles?
Is it charging but not turning on?
Then this is the guide for you!!
A very common problem with the DS Lite is that when it is dropped a small chip called the L2 Inductor comes away from the motherboard. This will still enable the DS to charge but you will not be able to switch it on. This guide will take you through step by step how to repair your DS Lite.
Things you will need :-
If you are lucky then your L2 inductor is still rattling around inside your DS. If it is lost then they can be bought very cheaply off of ebay :- L2 Inductor Ebay (Please note - This is not my ebay username, just the person that I always get my parts from)
Ok now we have everything it is time to start. Clear a nice big area for you to work in.
First remove any game cartridges from their slots and the DS stylus, like so -
Next remove the battery cover and 2 small rubber bungs here -
Underneath the 2 rubber bungs are 2 phillips screws.
Next remove the battery and take out the circled 3 phillips screws. You do not need to remove the uncircled phillips screw in the battery compartment.
Next, remove the 4 circled tri-wing screws using the tri-wing screwdriver -
Ok, thats all the screws removed, now to lift the case off. Pulling up from the back with 2 fingers on the shoulder buttons gently pull up and towards you but only enough so that you can get the case tool in to help with leverage. See below pictures -
Work the case tool around the gap and the top cover should lift off easily. DO NOT FORCE IT! You will then be able to see the motherboard like so -
The L2 Inductor sits to the left of the motherboard, right underneath the power switch -
Make sure that when you took the case apart if the L2 inductor was rattling around, it has not been lost. Hopefully you have managed to find it. What you need to do now is resolder the L2 inductor back onto the motherboard. Hold the L2 Inductor in place and carefully apply the soldering iron to each end, like so (it does not matter which way round the L2 Inductor goes) -
If you need to hold the L2 Inductor use something like tweezers.
Once you have secured the L2 Inductor onto the motherboard apply a tiny amount of solder onto each end of the L2 Inductor just to give it a bit more strength.
Thats it! You are done! Congratulations, you have repaired your DS Lite!
Now all you have to do is put it back together and you are finished. There are a couple of important things you need to know when putting your DS Lite back together.
You must make sure both the power switch slider and the volume switch slider are in the right place. The power switch slider should spring back to where it is supposed to but these pictures will confirm where they need to be -
Volume switch all the way to the left
Power switch all the way to the right as you look at it
The case sliders also need to be in the right place too, if you do not get this right you will break the little tabs off of the switches!
Volume slider all the way to the left
Power slider all the way to the right
When you re-assemble your ds, start refitting the case from the front backwards. Get it all in line on the front and the back should drop down with ease. Again do not force anything!!
Replace all the screws in reverse order and you are 100% done!! Give yourself a pat on the back!!
on Aug 30, 2010 | Nintendo DS Lite Console
My tomtom 910
Have same thing. I did call Tomtom and they are guessing ,just like me ,that battery is dead and offered me US$ 75 off brand new go 730 and old one u can keep. Was told ,they dont sell battery replacement .
Sounds like someone will sue their **** soon as class action .
Sep 05, 2009 | Tomtom GO 910 GPS Receiver
Inductor L2 Broken of NDS Lite
0 Ohms. You can just bridge it with solder.
Jun 26, 2009 | Nintendo DS Lite Console
Specs GPS GO 910 Tomtom
yes it should come with a universal voltage adapter and eu two pin connector.
Apr 11, 2009 | Tomtom Go 910 (Europe, USA and Canada...
I need motherboard for tomtom go 910.
http://www.portatronics.com/product_info.php?info=p672_TomTom-Go-910-Motherboard.html
Dec 11, 2008 | Tomtom GO 910
Tomtom 910 dark screen
If the LCD backlight is gone theres no choice but to replace the whole screen ( OR it could be the LCD lamp driver circuit on the circuit board ) . It's not economical to purchase a new screen but it is possible to purchase a defunct 910 , typicaly off ebay and use the screen from it . ( ensure you are buying a tomtom with a good intact screen ) . Changing the screen is tricky and fiddly but someone with general electronics knowledge should'nt find it difficult. You also need the special "star" drivers for the screws ( sometimes known as ' torxs ' ). If you are inexperienced with this sort of work then its best not to attempt it. There are companies advertising that can do this type of work for you and especialy in UK......... Good luck.
Oct 29, 2008 | Tomtom GO 910 GPS Receiver
Ds Lite not power up L2 Inductor is not good not work.
For the L2 L4 inductor specification, I check the following website, on there have original L2,l4 inductor power and specification
http://www.logictoyz.com/nintendo-ds/nintendo-ds-lite-spare-parts/ds-lite-l2-inductor-power-replacement-.html
By the way,L2,L4 is not fuse,
It is Inductor power
May 30, 2008 | Nintendo DS Lite Console
TomTom 910 problem
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
STEP 1
Connect your TomTom to your
computer True True (``````````` (``````````` 0 95250 95250 clip_image002.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the
backup True True (``````````` (``````````` 0 95250 95250 clip_image002.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 21, 2008 | Tomtom GO 910 GPS Receiver
TomTom GO 910 - screensaver?
try this it does take a while to do.
STEP 1
Connect your TomTom to your computer1.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
STEP 2
STEP 3
Copy the Yellow Folders from the backup1.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 Logo
272 people viewed this question
Top Tomtom Computers & Internet Experts
nix_bid
Level 1 Expert
Tom Chichester
Moazzem Hossain
Moazzem Hossain
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
